Question about Onkyo HTR500 Receiver
Onkyo HT-R500 prende y apaga porpadeo de led - Onkyo HTR500 Receiver
5 Suggested Answers
  • 319 Answers
SOURCE: wireing
Consult HT-R500 operations manual for hook up
Posted on Apr 27, 2008
tech48
  • 624 Answers
SOURCE: ht-r500 onkyo
When a receiver does this, it is know as the "protect mode". This keeps the receiver from causing more damage to the components in it, by shutting it off when it detects an abnormal amount of voltage or current.
If you had to replace the fuses, it is most likely that you have a blown channel in the receiver.
You put 8 amp fuses in, so I hope that the fuses that blew were 8 amps as well. If you put fuses in that are higher rated in amps than the ones that blew, you will most likely cause more damage to the unit than need be. If the fuses keep blowing, please stop putting new fuses in again until the unit is repaired. Every time a fuse blows, it is because of too much current is going thru the unit. Having too much current is a very bad thing for electronics, it causes components to short out and sometimes even catch fire if the fuse is higher rated than it is supposed to be.
To find out just what parts will need to be replaced, you need a multimeter and then you will need soldering tools to remove the bad parts and put the new ones in.
When an amplifier channel gets blown, there are normally around 5 to 10 parts that will need to be replaced. If you do not replace every single bad part in the channel that has blown, you will most times blow up all the new parts that you just put in.
If you have no experience with electronics, you really should take it in to a service center for repair. If you are willing to try it yourself, let me know and I will guide you thru the troubleshooting steps to help you identify all the faulty components.
Onkyo is very well made equipment and is worth getting fixed.
A blown channel can normally be repaired for around $100 to $150, just depending on the shops rates and the extent of the damage.
Let me know if you need more help.
Dave
Posted on Jul 27, 2008
  • 15 Answers
SOURCE: onkyo HT-R500 amplifier protection circuitry activated
u have a short.
remove all speakers cables and turn it on, if remains on and u can up the volume do the next.
1: turn it off.
2: connect only 1 speaker cable (each time to see if the short is in one speaker or cable)
3: turn it on, up the volume.
this way u must be able to see what cable or speaker have the problem.
if still the same prob the short is inside.
i put a answer of a prob where cant up of 41 check the cleaning method.
Good luck
Posted on Jan 12, 2009
  • 153 Answers
SOURCE: Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Posted on Apr 21, 2009
Tengo una Lincoln Mkx 2007 con 69900km y al girar el switch con su llave adecuada prende el candado y se apaga intermitente y da un pitido de aviso bajo el tablero y no enciende regreso el switch a...
Puede ser un modulo que esta malo eso es lo mejor llevar lo al dealer para que lo chequen.
Mira ver si lo puedes llevar a advance auto parts para que te chequen el alternador puede ser que esta mandando mucho voltaje a lo modulos y causa que el systema se apague.
Feb 03, 2015 | 2007 Lincoln MKX
How to setup
http://www.manualslib.com/manual/302221/Onkyo-Ht-R500.html
Jan 10, 2015 | Onkyo Ht-r500 5.1 Channels Receiver A/v...
Mi tele solo prende y dura un poquito y se apaga
mi vizio se prende y de momento se apaga y se pone ***** ademas no tiene sonido q puedo hacer
Mar 05, 2012 | Vizio L32 32 in. LCD HDTV
Mi televisor se prende y se apaga tiene tres focos en la parte delantera uno dice lam temp power el de powewr parpadea y no se queda fijo que puede ser
mi tv ultravision hitachi prende y se apaga lo desconecto y lo conecto y prende y hace lo mismo y m parpadea la luz roja d temp q sera ?
Dec 09, 2010 | Hitachi UltraVision 55HDS52 Television
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
LA FALLA ES EL PROYECTOR PRENDE CON SU LAMPARA NORMAL Y A LOS 5 SEGUNDOS DE ENCENDIDO SE APAGA Y QUEDA PRENDIDO EL LED INDICADOR DE LAMP
compruebe la lámpara para saber si hay bombeos, puntos negros, o empañarse. substituya si está necesitado. si no, substituya el lastre/la fuente de alimentación.
Jan 27, 2010 | Christie Vivid LX41 Multimedia Projector
SE PRENDE EL CHECK ENGINE Y SOLO SE APAGA CUANDO
dé vuelta a la llave de ignición 40 veces de apagado a encendido
Dec 12, 2009 | 1997 Mercury Villager
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Wireing
Feb 08, 2008 | Onkyo HTR500 Receiver
Encendido del LC-32GA5U
no abla espanol this is america translate your question first
Dec 30, 2007 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Onkyo HTR500 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
