Question about Kyocera Fsc1020 Colour Multifunction Laser Printer
Need Fuser / Maintenance Kit for the Kyocera Mita FSC1020MFP
I have not been able to locate the fuser assembly for this model. Anyone know where to buy it?
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 4090 Answers
SOURCE: wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Posted on Jun 23, 2009
  • 266 Answers
SOURCE: Where can I get a e manual for mita FS-1118MFP
you will get it from http://www.kyoceramita.eu/index/service/dlc.false.documentation.FS1118MFP._.EN.html
under DOCUMENTATION TAB
Posted on Mar 04, 2010
  • 95 Answers
SOURCE: kYOCERA fs-1920 Has the message instal
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Posted on Sep 08, 2010
shawn38
  • 200 Answers
SOURCE: Kyocera FS-2000D This printer comes
Yes it is a fuser error.
6120 Abnormally high fuser thermistor S temperature
*35/37 and 45/47 ppm printers (EUR/USA model) only
The temperature of the fuser thermistor S detects 250°C/482°F or more continuously for 3 s.
Shorted fuser thermistor S.
1. Measure the resistance. If it is 0 ω, replace the fuser thermistor S.
2. Defective engine PWB.
Replace the engine PWB
Posted on Mar 11, 2011
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Dec 11, 2014 | Copystar Office Equipment & Supplies
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
Kyocera Printer FS2000-D says "install
You need to turn off the printer and unplug it then install the items from the maintenance kit.
Mar 31, 2011 | Kyocera MAINT KIT: DRUM, DEVELOPER, FEED &...
When I print in black form a Kyocera Mita FS-C5016N printer the ink looks smduge. Do you have any suggestions/solutions for this?
It could be a fuser, drum, developer, or transport belt problem among other things. The FS-C5016N is an old model color printer and if the maintenance kit has not been replaced it probably should be. THe maintenance kit contains the items above along with a few others.
Aug 17, 2010 | Kyocera Mita FS-C5016N Printer
MAINTENACE TIME DISPLAYED ON MY km-2030
You need a technician to install a Maintenance kit. It consists of a new drum, developer unit, fuser and feed rollers.
Jun 02, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
Oct 05, 2009 | Kyocera Mita KYOCERA/MITA AS-M4110 Copier
Mita all copies have clean, thin, black streaks
Needs a clean around the fuser area. You may see a build up of toner near the rollers which is being drawn in. There's an outside chance that the lens needs cleaning also.
Jul 07, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Install MK
Machine maintenance(400,000 printed pages) Content of MK : Fuser assembly,Developer assembly,Drum assemby, various feed and other rollers,transfer assembly etc...
BR
Mar 27, 2008 | Kyocera Mita FS-9120DN Laser Printer
Kyocera Fsc1020 Colour Multifunction Laser Printer Logo
424 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
