Question about Vacuums
How do I take the on/off switch out to repair broken wire
Motor stopped running
have you checked the crankshaft positioning sensor?it will stop the car from running and getting fire
Aug 21, 2008 | Shop Vac Vacuums
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
It got cloggged up, so i fixed the problem and nowit wont come on
1) you must test the power cord for open, broken wires repair
2) test the power switch for open or defective, replace, or repair any wires loose or open.
3) test the motor for faulty, brush, or winding open or overheating repair or replace.
God bless you
Jun 28, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No power to vacuum - internal fuse? switch?
I would contact a local vacuum cleaner repair shop and ask this question.
Apr 20, 2017 | Dirt Devil Featherlite Bagless Upright...
My electrolux Epic 6500 power nozzle Model N109J will not work. It had an intermittent short which I thought I fixed (some of the insulation on the wires were pinched). I fixed the wires and it worked...
The switch is definitely a possibility, but other problems can also cause this.
Bad switch, needs replaced.
Broken wiring in power nozzle, wands, hose, or canister.
Bad PN motor.
I strongly recommend taking it to the nearest authorized Aerus Electrolux store for a diagnosis (should be free). Allowing them to do any repairs necessary is recommended, as well. This will ensure it's done correctly.
http://www.aerushome.com/storelocator/
Feb 23, 2011 | Electrolux Epic 6500 Vacuum
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Have no power to unit. have cleaned everything, but still no power
Please advise brand. Some vacuums have switches that become defective. I suggest using a VOM (Volt/Ohm/Meter) and follow the current into the vacuum. If it come to the switch, but not out of the switch - replace switch. Make sure cord is not frayed with a broken wire inside. Again the volt meter will ferret that out. If the motor has motor brushes one could be sticking or worn - replace.
If you are not comfortable working with electricity, please consult a reliable repair man
Mar 08, 2009 | Vacuums
Power on
Hello markswifey92. Check your AC cord & plug. There maybe a wire broken. Be careful of exposed wire. #2 May be a bad power switch. Please inform me of the results and I will provide repair steps. Please include Mgfr, model & serial#. Good luck.
Sep 27, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Broken on/off switch
I have the same vacuum and the on/off switch wasn't working any longer so I took the cover off to find out that the wiring got so hot that it melted through the wire coating and plastic frame.
Aug 04, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
