Question about Maytag Washing Machines
My Matag MAH4000AWW has a problem with water in the bottom of the barrel, takes a couple of days to notice.
After a wash cycle unplug machine. if no water accumulates then the main water valve train is bad. replace it. or simply unplug the washer when not in use
Posted on Jun 24, 2009
Ge Monogram all in one refrigerator model zir36nmdlh is leaking and freezing food
There is a heater element that helps to defrost the coil, you may need to replace it.
May 04, 2014 | Home
Matag Mod. MSD2554ARA leaking water on the floor
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill.
Apr 25, 2012 | Maytag Matag 25.6 Cu Ft Side By Side...
My matag diswasher fills with water without being used. The process is gradual and takes several days.
two things, your water inlet valve could be going bad. your drain hose from dishwasher is lower than the sink, so whenever the sink is being used, water will slowly back up into dishwasher. if this is the case, just loop the drain hose under the sink, this should solve your problem
Feb 03, 2011 | Maytag Dishwasher
Samsung refrigerator had water leaking into bottom
Is he an authorized Samsung/Matag Repair Center Employee? And I believe I know the answer. But you need to communicate with me, OK? How old is your model?
Thanks, Sea Breeze
Apr 09, 2010 | Samsung RB2155SH Bottom Freezer...
I have noticed a couple of drops of anti freeze on the floor the last couple of days the bottom of the car is starting to get wet with antifreeze
Right above the water pump there's a 90 degree elbow that's made out of plastic that comes out of the intake and goes to a heater core hose. That's where mine was leaking. Get it replaced soon because it will get worse. I heard this is common on these 3.8L engine.
Nov 09, 2009 | 2004 Pontiac Grand Prix
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
