Question about Honeywell Programmable Thermostat Heater
Help help help!!!!!!!!!
After nearly being fried i figured i better ask a pro.how do you wire a honeywell thermostat with gr
    Sergeant:
  • 359 Answers
Not enouge iinfo
Posted on Oct 26, 2008
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
Need to know correct color wiring from goodman model gph1330h41 with heat kit to honeywell model th5220d thermostat. Thanks
here is the wiring from man. f you have trouble figuring out the programing or what terminals to use in thermostat there is an help phone number. Be shure to turn off all power to unit and thermostat, remove batteries from thermostat.
jl+ax8un4pr7j8pz3ifmkacgi5aaaaaelftksuqmcc
May 12, 2014 | Honeywell Electronic Programmable...
HAVE A HONEYWELL THREMOSTAT TH8000 NEED WIRING HELP HEAT IS COOL COOL IS HEAT
Most of the time the white wire hooks to W and the yellow wire hooks to Y....... W= Heat Y= Cooling In any case if you are getting Heat when you set the thermostat to Cooling....... Turn the furnace off at the ssu or main breaker and then ... Pop the thermostat off of the subase and switch the wires that you have on Y with W and put the wire from Y to W.... Here is some more information on how a typical thermostat is wire in the pdf..... Hope this helps...
Here is a pdf for the installlation manual for a Pro 8000
http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf
May 05, 2011 | Honeywell Heating & Cooling
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Switching thermostats
http://www.toad.net/~jsmeenen/wiring.html
Go to this site and you will better understand how thermostats are wired.
May 04, 2009 | Honeywell Electronic Programmable...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
