Question about Taylor Health & Beauty
How to change battery taylor 5729
Unclear how battery is supposed to go in. There is a metal piece at top edge of battery compartment. Does this stay on top of batteries or does it need to be folded into compartment. Replaced batteries as were in device didn't work.
  • 10865 Answers
SOURCE: Lost manual, need instruction on how to reset Taylor 5700 BMI
personalcare.owneriq.net/manuals/mfg/taylor/5571.html
go to that address and you can download the manual.
Posted on Feb 14, 2009
r321567499
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Posted on Feb 08, 2009
skaterkid307
  • 86 Answers
SOURCE: How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Posted on Feb 20, 2010
rockmeister
  • 2047 Answers
SOURCE: Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Posted on Sep 02, 2010
New batteries but will not stay on
check for loose or shorted connection inside the scale.
Dec 05, 2013 | Taylor & Digital Scale Lithium Scale
Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
Jan 14, 2012 | Measuring Tools & Sensors
Replace system battery,with power on?
The Partner ACS system uses 2 AAA batteries to retain programming from 45 to180 days, in the event of a power outage. When these batteries fail, a system warning (replace sys bat w/ power on) will display on the screen of extensions 10 and 11.With new batteries in hand, go to the phone system cabinet and find the system processor. The system processor will be marked on the top third of the card with a label marked "Partner ACS processor".
On the bottom of the processor module,below the extension jacks, there is a battery compartment. With the power on, Push in slightly on the battery compartment and slide the black locking latch up to cover the"+" icon. Remove the battery assembly by pulling the tab at the bottom of the compartment cover.Place the batteries into the metal battery clips fully. Make sure the polarity of the batteries is correct by looking inside the metal battery clips for the "+" and "-" icons cut into the metal of the battery clip. With the locking latch in the unlocked (up) position slide the battery assembly back into the processor card far enough that the edges of the assembly slip behind the plastic housing of the processor card.Slide the locking latch down to secure the battery compartment. The message on your screen will disappear if the batteries are inserted correctly.
Dec 21, 2010 | Lucent PARTNER18 Corded Phone
My Canon claims that I need to change the batteries. However, I have changed them out 3 times with brand new batteries. It is now dead and won't turn on.
Here is the suggestion:
The battery compartment cover and the design of the metal electrical contacts is flawed. These acontacts re made of springy metal, but there isn't enough force to press the metal securely against the battery. The end of each contact has a metal tab that prevents it from being bent further out to increase the tension. These contacts are the cause of the low-battery warning.
Some fixed the camera by inserting tiny pieces of plastic foam (i.e., spongy, like from "foam rubber" pillows) under the metal contacts. Used a small screwdriver to gently bend up each metal strip, and stuffed a small piece of foam under it. This provides enough force to keep the contact securely touching the battery.
or You can also try the "toothpick trick" as described in various forums, and it seems to be working. There is a belief that there is a design flaw with the battery compartment door, or the springs that press against the battery. By wedging a toothpick under the battery contacts, it seems to force the contacts into the battery, seemingly helping with the problem that many are facing in this and other forums.
Nov 08, 2010 | Canon PowerShot A560 Digital Camera
Weber Q 120--propane leak when removing canister
i would say that might be faulty mine just screws together and unscrews nothing falls out
Apr 20, 2010 | Weber Baby Q Grill
I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
Feb 02, 2010 | Fitness Quest Cycling
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
2003 audi replacing the battery
I found this ....
Though not the best design - it is doable with simple tools. Note: my car is: Audi 2003 / 2004 Quattro A4 3.01. Remove weather stripping (3/4" thick strip across top of sheet metal between engine and fire wall (just give it a tug to get it going)
2. Remove plastic shield covering battery (remove the small one above the battery to give youself some leverage point). To remove the large plastic piece just pull up on the front edge of it first (along the entire edge) - there will be a metal clip or two unless they fell off. Then pull it out of the recessed edge (other side) - it comes out as one piece. Note where the metal clips were! :)
3. Lay cloth on side of car. :)
4. If you have time run to Sears (or local tool shop) and buy metric allen heads for your nut-driver or socket set nut-driver. This will save you a headache....
5. Remove the positive and negative leads (I like to wrap the + cable in cloth so it doesn't touch anything....
6. My radio etc. were all fine. Alarm was fine so no need to do the battery trick...
7. If you don't have a nut-driver/allen set (like me since it was Sunday night) just use a #6 allen wrench with a ball tip (not necessary but helps)
8. The screw that holds the battery wedge in place is in a terrible spot - the front center of the battery. If they had only made a cut-out in the sheet metal this would be simple. But....they didnt' So use your allen wrench along with some pliers to un-do the cap-head screw. Don't worry, it is locked into the plastic piece so it won't fall into the bottom of the engine compartment.
9. Slide the battery screw over out of the way
10. Remove the breather tube on the + side of the battery
11. Tilt the battery backwards, slide it out - Again, Audi, just another 1/4" here would have been nice!!! you may have to cut the zip-tie on the + cable cover to get the battery out. I did.
12. put new battery in
13. Replace all the gear in reverse order.
Aug 19, 2008 | 2003 Audi A4 Cabriolet
Canon A310 Won't Power Up.
Try checking this... on the battery door (the outside door) along the top edge (over the CF card pointer embossed in the back of the door) you should see a little plastic piece that pokes out... tis is supposed to push a small switch located in a slot over the battery compartment. It's the sensor that tells if the battery door is open or closed.. if the plastic part breaks off or gets chipped it wont push the button and the camera will not turn on when the shutter door is opened.
Jun 09, 2007 | Canon PowerShot A310 Digital Camera
Health & Beauty Logo
513 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
