Question about Denon AVR 3808Ci Receiver
Amp problem, blown channel?
I have an ancient Pioneer sa-900 amp. I dug it up from my dads garage and it probably hasn't been used in 25 years. When I hooked it up it started out fine, but seems to fade out on one side after awhile. I was told it was probably a blown channel. Any expertise on the subject would be greatly appreciated. I'm wondering if it would be worth taking apart and trying to fix.
Thanks, Lindsay
  • Cruckshank Oct 25, 2008
    Thank you mistersony and benimur for the advice, much appreciated. I will try cleaning it like u say and let you know what happens.
  • 320 Answers
I would bet that your problem is more likely caused by the long sit and less a blown channel. First thing I would do is take the unit apart and clean all of the switches and controls with something like Caig Labs R5 (available from MCM electronics and from Amazon). Pay special attention to the tape monitor switches and the speaker relay, as those are the most common causes of lost sound on one channel. The easiest way to clean the speaker relay (once you have the cover off) is to take a sheet of plain white paper, cut a thin strip off and saturate it with the R5 and then slide it through the relay contacts witht relay closed. I'll bet after you do taht, you'll see that the paper has black streaks where you have cleaned corrosion and oxidation off the relay contacts.
Posted on Oct 24, 2008
    Brigadier General:
  • 6,966 Answers
Congratulations, the Pioneer SA-900 is already a classic, a legendary pre-amp/amp unit. It is not as high powered as today models but certainly can hold its own. Offhand, there would be three (3) ways you can attend to the concern:
  • perform a DIY (do-it-yourself);
  • seek the services of a reputable audio shop;
  • seek the services of a professional classic audio equipment restorer.
Should you be considering a DIY, it might be to your advantage to have access to a service manual. This of course requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron.
This might be informative.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Need service manual for pioneer sa-600
Head straight to the (European) electrotanya website, which offers free downloads of a wide range of service manuals. No registration is required either.
The Pioneer SA-600 schematic shows both voltages and currents. For this amp, the total current for left & right output modules (no signal) is 60mA. No-load voltage is 58 volts, dropping to 48 volts (one channel driven, 25 watts out).
PIONEER SA 600 SCH Service Manual free download schematics eeprom...
Feb 26, 2014 | Cameras
I have a pioneer sa-8100 amp. Left channel goes off shortly after playing it. What is wrong?
Could be a lot of things. More triage is needed.
Have you done any isolation to prove/disprove a certain source, channel cable or speaker are NOT the problem first?
May 26, 2011 | Pioneer Audio Players & Recorders
My technics sa-ex 300 wont power up it keeps saying over load can i fix it?
Unplug the speakers and try it again. If it still does it then one amp channel is probably blown
If it stops then the speaker is faulty or wire may be shorting
Sep 03, 2010 | Technics Audio Players & Recorders
Blown fuse in stereo amp
well fuse get burnt when there is heavy current flow than the fuse rating so there is heavy current flow and this current flow might be because off short circuit in the PCB and this short circuit might be because of any transistor breakdown so u have to check through the PCB.(Printed Circuit Board)
Jan 05, 2010 | Audio Players & Recorders
There's an ancient Remington 10 typewriter in my attic - levers and knobs all over the place, and even a space bar made of wood! Is it any use to anyone?
Usually very little value to old typewriters. Too many made. Either put on e-bay and see if you can get $20-25 or put in a garage sale. If you're in no hurry, keep it in the attic for another 20 years and see if the market improves! :)
Oct 14, 2009 | Office Equipment & Supplies
I have a technics sa-ax7 receiver and have sudenly lost sound on the right hand speakers.can they still be repaired. What could be the problem. Thanks
1). Look for a blown fuse on back - or inside. I had this similar problem with a Technics SA 5060 (vintage) receiver, and there were 2 separate fuses for left and right channels. One may be blown.
2). Try switching speakers (physically switch the left and right input plugs in their jacks - or wires if no jacks. If the left speaker doesn't work now, there is an issue with the speaker that has no sound. Run an ohm meter on these speakers as well to check them. There should be 8 ohms approximately. If no reading, then your apeaker is probably blown. If you can see a short on ohm meter 0 ohms) then you have a short circuit in your speaker.
Fred
Sep 21, 2009 | Technics SA-AX7
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Denon AVR 3808Ci Receiver Logo
1,097 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
