Question about Audiovox - AS-9903 - Six Tone Car Alarm Siren, 120db 20 Watt
I have a 1997 toyota camry, i have a AS-9903 alarm, but my car doent want to start, it has 2 switches, one to turn on and off and one is black, i tried to turn on with the key but it doesnt do anything. what can i do?
2 Suggested Answers
  • 50 Answers
SOURCE: camry 1995 AS-9903 Alarm Problem
LOOK FOR A TOGGLE SWITCH IN DRIVERS KICK PANEL. ONCE FOUND TURN KEY ON THEN FLIP SWITCH.
IF ITS A PUSH BUTTON SWITCH THEN TURN KEY ON AND THEN HOLD THE BLACK VALET SWITCH DOWN FOR 8-10 SECONDS.
DONT LET MORE THEN 5 SECONDS GO BUY BETWEEN STEPS.
Posted on Jan 22, 2010
1996 Camry was running fine yesterday.This morning it wont start.
1996 Toyota Camry WONT START PLEASE HElp!!! - YouTube
? 3:18
https://www.youtube.com/watch?v=kgChwyign1M
Jan 2, 2013 - Uploaded by Jabali Black
My car problem started 3 days ago, it started with my Toyota security light blinking red, then a key like symbol on ...
96 Camry won't start / drivin me crazy - Toyota Nation Forum ...
www.toyotanation.com/...1996.../273708-96-camry-won-t-start-drivin-...
Nov 10, 2008 - 15 posts - ‎4 authors
I took my 96 4cyl Camry to the shop due to working nightshift for now and ... (1992-1996 & 1997-2001) > 96 Camry won't start / drivin me crazy ... camry wont start or crank on one click sound
Mar 5, 2011
94 Camry Won't Start after Timing Belt Replacement
Nov 20, 2010
93' Camry 4 cylinder, Cranks but won't start up
Sep 15, 2007
1992 Camry 2.2 Turns over Won't start
Feb 27, 2004
More results from www.toyotanation.com
Jan 15, 2016 | Cars & Trucks
94 camry alarm would'nt stop i pulled a black wir next to the horn now car wont start
the wire from the horn is part of an imobiliser so it wont start replace wire it sounds like imobiliser battery or alarm pad if wont turn off
Oct 13, 2012 | Toyota Camry Cars & Trucks
Whenever i unlock my camry manualy ( key in the door ) the alarm goes off. Also if i open the back door before the front door the alarm goes off. I have to use the remote key or i cant get into my car and...
this is due to a bad switch in the drivers door, when you use the key to unlock the door it should shut down alarm, also the alarm module may be going bad, the alarm is setting itself on, when ever you lock the door the alarm turns on, you will need to replace the switch on the drivers door or unlock the passenger side door that also has a switch that disarms it, the switch is on the lock itself, thats the problem you are having , good day,
Apr 15, 2011 | 1997 Toyota Camry
I have a 1997 Toyota Camry. Recently, the security alarm malfunctioned, blaring the alarm and the remote control on the keys wont deactivate the system even after changing the batteries on them. I recently...
You need to reset the alarm by inserting the reset key(small plastic devise with visible contactors that should be with the keys) for a few seconds in the it's hole in the right-hand rear speaker. Open the boot look at the underside of the rear right-hand speaker to locate the hole.
Jul 03, 2017 | 1997 Toyota Camry
I had to change the battery. After replacing the new battery all systems work, but the car won't turn over and the factory alarm is blaring. How do I disable the factory alarm? I do not have the...
If you have the Toyota factory alarm, there should be button under the driver's side dash to reset the alarm....Look for it 1st, then read below.
Put the key in the ignition, and turn forward
all the way just before cranking, to the ON position.
Then within 5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
GL,
Td
Aug 10, 2010 | 1997 Toyota Camry
Camry 1995 AS-9903 Alarm Problem
Nov 25, 2009 | Audiovox - AS-9903 - Six Tone Car Alarm...
Cant turn key to start 1997 toyota camry. tried all keys to car. after hours of jiggling key it catches and turns ignition to start. Do I need to replace ignition or tumblers in switch. If so HOW
Yes you do need to charge the ignition barrel as it sounds as if the current one knakered, try going to the scrappy but be sure to get a barrel that they have the keys for also remember to keep your other keys for your car.
Best Wishes
Jimba
Jul 13, 2009 | 1997 Toyota Camry
Car wont start alarm light is blinking
yes factory alarm. there is a smal switch hiden under dasch board find it and turn the alarm of by reseting the boutton you can also open the driver side of car witt your keys
Dec 14, 2008 | 1994 Toyota Camry
Car alarm won't disactivate
try turning the key almost to start and keep it there for about ten minutes. hope it works. I got this tip from somebody else.
Nov 15, 2008 | 1997 Toyota Camry
How to turn off the alarm manually without any use of a remote control
Just unlocking the car with the key turns the alarm off.
Jul 04, 2008 | 1997 Toyota Camry
Audiovox - AS-9903 - Six Tone Car Alarm Siren, 120db 20 Watt Logo
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
