Question about Home
How do i replace stabilizer valve main seal on a triton jade electric shower
I have a problem releasing the stabilzer valve
peterrance19
  • 399 Answers
SOURCE: triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Posted on Nov 15, 2009
citroenchris
  • 600 Answers
SOURCE: the water on my triton jade shower comes through
you need to increase the water flow, check for a stop valve not fully open or perhaps a leak outside , you might need to contact your water supplier.
Posted on Mar 19, 2010
  • 2602 Answers
SOURCE: hi i want to replace my mains fed shower with a
I would ask at the local plumbing shop they will have all the info you need there
Posted on Apr 20, 2010
SOURCE: My Triton (Jade) electric shower has abruptly
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Posted on May 06, 2011
  • 17 Answers
SOURCE: triton jade shower will run so long then low pressure light comes on and shower stops
heating up breaking contact Replace the switch with a 45 amp DP type then try the shower again you may have two faults but more than likely just the one switch . good luck
Posted on Aug 26, 2012
I have a Triton T80Z electric shower and water is coming from the pressure release valve. I have a replacement valve but I don't know what needs to be done to recommission it can you tell me please?
Let the water flow out of shower with out the heat on to remove air from water line once this is done . it should work fine with the heat on .
Jun 18, 2017 | Home
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Triton jade shower will run so long then low pressure light comes on and shower stops
Aug 26, 2012 | Home
I have a triton r2 which has suddenly stopp working no water no power there is power at isolating switch
My guess is that the solenoid valve on the inlet pipe has died. This assembly is held closed by water pressure and power is needed to pull it back to allow water through to the heater coils. These systems are designed not to operate in the absence of water flow for safety reasons. The valve will be fine, it is the electrical coil within the solenoid which is at fault. Disconnect the shower unit from the mains supply and disconnect the solenoid terminals, Its the little cylindrical device immediately to the right to the stabiliser valve (the lower knob). Try a voltmeter across the solenoid and it should register some continuity, if no continuity the coil is fried. Triton will be the best place to get a replacement part.
Apr 29, 2010 | Water Pik Waterpik& Elements& Fixed Mount...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
Stew.
Apr 05, 2010 | Home
The water on my triton jade shower comes through red hot all the time
Mar 16, 2010 | Home
Triton jade 2 shower not generating sufficient heat
Nov 11, 2009 | Home
Home Logo
130 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
