Question about Craftsman Air Tools & Compressors
Craftman model 919.152920 will not build pressure over 20 psi. i heard a noise like an airhose broke a few minutes after starting no leaks anywhere.
Model # 919.152920 4hp 25 gal single piston
SOURCE: compressor will not build pressure
Posted on Feb 28, 2009
  • 98 Answers
SOURCE: My craftsman 25 gal. 5 hp. compressor builds 120
Replace check valve the piston is getting stuck sometimes alloying the air to leak all the way down till it comes back on
Posted on Jul 21, 2009
  • 199 Answers
SOURCE: I have a 25 gal compressor and it will not build
You got a good life time with this. The compressor has seals or "rings" which wear out over time. Replace them and your compressor will love you. It won't hurt to check all the lubrication points. This procedure is easy for even a novice but may require a special tool. Go to your local small engine repair shop and ask. They will be glad to help you.
Posted on Aug 05, 2009
  • 5603 Answers
SOURCE: My craftsman air compressor model 919 16737 1.1 hp
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Posted on Aug 24, 2009
  • 114 Answers
SOURCE: compressor won't build psi above 30,is this
Or maybe someone has played with the Regulator and adjusted it to this????
Try readjusting the regulator first and if that doesn't work, get a new regulator.
Posted on Jan 30, 2010
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
Craftman lawn tractor
the newer fuel has been giving problems to the rubber seal for the needle and seat in the carb so what happens is the carb over fills with gas and then flows into the intake and crankcase then when in the cylinder it hydrolocks not letting the engine turn over change the needle and seat in the carb change the oil add a shut off valve on the fuel line and shut it off when not in use and if storing for more than a few days run the carb out of gas by shutting the shut off valve and let it run out of gas in the carb this will reduce it happening again
Jul 10, 2012 | Garden
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
It will not build pressure in the tank.
There is a pressure relief valve somewhere around the motor. Make sure it is closed. If the relief valve isnt leaking air while the compressor is running you probably have a loose hose on the line going from the compressor to the guages or the overpressure valve. Something under the motor/compressor cover.
Jun 30, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
Car stalls when oil pressure drops...20 minutes to restart
No it is a fail safe. When your oil pressure drops below (on most cars) 30 psi your computer will shut your fuel pump down until you either let it sit for a while and it resets or until oil pressure builds again. Sorry!
Mar 11, 2009 | 1992 Buick Roadmaster
Alero will crank awhile before it finally starts w/ more details
May have small fuel leak or fuel pump sending unit leak down. Or fuel pump psi low.
After 30 minutes try this turn key on. do not try to start wait 10 seconds turn key off then on again 10 seconds then try & start if it starts right away fuel system is losing PSI either back through the fuel pump or a leak in line. If you can find no leaks would suggest replace fuel pump & assembly.
Another possible but rare fuel injectors may be leaking fuel over time & dropping PSI needed for start up.
Mar 08, 2009 | 2001 Oldsmobile Alero
Wont build pressure over 25 psi after rebuild
sounds like the belt is slipping have you checked the inlet and discharge valves also could be bad and leaking or stuck or installed wrong
Feb 19, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
174 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
