Question about Maytag MDE9700AYM Electric Dryer
Where is the thermostat on a maytag neptune electric dryer mde9700aym
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Can the Maytag Neptune Gas dryer converted to electric?
A gas dryer is dedicated to the use of gas to supply its heating function. It works on 125 volts. No way can a gas dryer become an electric one. UNLESS!
you just want to hang out yer clothes under the sun and use the dryer as a way to fluuf up yer clothes OR you could place the dryer into a box and make a condenser dryer out of it. Like cool hand luke you will toss that dryer into a rigid metal box in direct sunlight so that it can be an unbearable 140 degree up in there. then grab yer clothes and toss em in there and close that tar paer lined tin box up my friend.Let the sun do its thang. I think i just invent the redneck dryer! we don't need no stinking gas. Green power to the people! LOL
Posted on Apr 08, 2009
  • 351 Answers
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
  • 93 Answers
SOURCE: Maytag Neptune Gas Dryer MDG9700AWM fire comes on
TAKE THE FRONT OFF THE BLOWER WHEEL- THE METAL COVER ON THE BOTTOM LEFT CORNER- CHECK THE PLASTIC WHEEL INSIDE - THE CENTRES OF THE WHEEL WEAR OUT
ALSO CHECK THAT ANY EXHAUST DUCTING IS CLEAR
Posted on Jul 10, 2009
Dryer runs and drys but makes a thump soud every revolution "like a tennis ball"
Check the belt that is on the drum. It sounds like it may have a chunk broken off of it and you may need to replace it.
Aug 09, 2014 | Maytag MDE9700AYM Electric Dryer
My neptune MDE9700AYW heat comes on for about min and half then goes out I have check all thermostats all four. I have been told it my be in the main panel
Have you cleaned the sensor strips with windex? They may have a coating of wax on them from dryer sheets and such. If no moisture is detected the brains of the thing shut it down.
Jan 09, 2013 | Maytag MDE9700AYM Electric Dryer
I have a maytag neptune dryer model mde9700aym. my problem is this we moved into a new home and when i plugged the dryer into the socket it did not sound like it should (it was very noisy), so i unplu
Its not level and the dryer blower is hitting. There are adjustable screws at each corner try rotating them out until you feel no wobbling or it doesn't shake. Also if you put to heavy of a load in it, it will also make that noise.
Dec 27, 2011 | Maytag MDE9700AYM Electric Dryer
Neptune dryer makes a banging noise on the left side each time the drum rotates
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | Maytag MDE9700AYM Electric Dryer
How do i get heat?
you probably burned out your heating element or the over temp thermostat
Feb 13, 2010 | Maytag MDE9700AYM Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Belt is broken on my Magtag Neptune Dryer #MDE3000AYW. How do I take the front panel off to get to the belt?
Hello del4221,
Here is a link to your dryers assembly drawings and parts lists. http://www.pcappliancerepair.com/model-display.php
You should be able to see how it is assembled and be able to disassemble it with this documentation.
Hope this helps..
Regards
Rick
Jan 07, 2009 | Maytag MDE9700AYM Electric Dryer
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Nov 10, 2007 | Maytag MDE9700AYM Electric Dryer
Maytag neptune dryer
could be the heater element, check for circuit with a test meter if it does not heat up in the minute it runs this is almost certainly your problem
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Open Questions:
See all Maytag MDE9700AYM Electric Dryer Questions
Maytag MDE9700AYM Electric Dryer Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
