Question about Mitsubishi Televison & Video
Bulb tweaking would like to know how screws on bulbs should be placed
  • 4 Answers
What kind of bulb need to replace....can light,flourescent,or another?
Posted on Feb 13, 2012
  • shade1813
    shade1813 Feb 13, 2012
    they are red blue and white all bulbs work and are in a box-like housing with adjustable screws and on the housing there are notch imprints almost to seem as if thay are used for adjustment...i was just wanting to know what the best placement for the adjustment screws were
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I have a Black and Decker Lithium Halogen Spotlight and need to know how it comes apart to replace the bulb. thank You
Pry off the rubber bezel with a flat head screwdriver, remove the Phillips head screw holding the reflector in place. to remove bulb you must loosen the phillips head screw and nut holding bulb in place , do not touch the bulb with bare hands use a paper towel or cloth, the oils in your skin will cause premature failure of bulb.
Sep 11, 2013 | Black and Decker USA Black & Decker...
High beam on headlight stoped working, fuse appears ok. Dont know how to go about changing the bulb out, if i have to get the bulb from motorcycle shop or can I get from like auto zone?
You can go to jpcycles.com for a better price than a dealer, AutoZone is for cars mainly. There is usually a single screw or several screws which hold the metal ring onto the bulb. Carefully remove the ring and the bulb should not fall out as it will be held in by it's plug. Sometimes there is an inner ring which holds the bulb and the chrome ring is just to make it look pretty. Remove that one as well. Install the new bulb in place of the old one and put the screws back in their proper places. That's it. This is a very simple fix.
Aug 30, 2011 | 2004 Honda VT 600 C Shadow
How to replace brake light on 1998 ram truck 1500
1.remove screws holding the light cover in place.
2. Remove plug from bulb
3. push and turn on bulb to release bulb from socket
4. insert new bulb
5. Plug in wire connecter
6. insert screws holding light cover in place
Mar 15, 2011 | 1998 Dodge Ram 1500 4WD
I need instructions on how to change the headlamp bulbs on a 2005 grand marquis. Please help.
To remove first you want to remove the headlight door mounting screws and remove the headlight door. Then you want to remove the 4 retainer ring screws and remove the retainer ring from the headlight. Then you want to pull the headlight bulb forward and detach the wiring connector.
To install you first want to a
ttach the wiring connector to the headlight bulb and place the bulb in position, locating the bulb glass tabs in the positioning slots. Then you will attach the bulb retainer ring to the assembly with the retainer ring screws. Then you will install the headlight door and secure with the screws. Then you will check the headlight bulb aim and adjust as necessary
Let me know if this helps you.
Mar 07, 2011 | 2005 Mercury Grand Marquis
The interior light no longer works.
Could be the bulb. Here is how to change it. The dryer bulb is located at the top left of the dryer rim. You will need a torx wrench the correct size to remove the screw that holds down the bulb cover. This type of wrench is available at your local home or auto store and is inexpensive. Once you loosen and remove the screw the cover will fall down. One end is hinged so that end remains in place. On the cover its tells you the type and wattage of bulb to buy. Ours is a 10 watt appliance bulb. You can take the burned out bulb to your local home store and they will get you what you need. The bulb screws in and out of the socket. Just screw the new bulb in and put the cover in back in place and screw the cover down. It is simple. Good luck
Dec 19, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
How do I replace the headlights in my 1985 Lincoln town car.
To replace the headlights, you must first remove the trim ring around the headlight. There should be three or four screws holding it in place. Once the trim ring is removed, there will be four screws, two at the top and two on the bottom. Carefully remove screws and remove the retaining ring. Gently pull bulb out, unplug the wire connector. With new bulb in hand, carefully connect the wiring to back of bulb and carefully set in place. While holding the bulb in place, set retaining ring back in place over bulb and insert screws. Then replace the trim ring, tighten the screws and you are done.
Jun 12, 2010 | 1985 Lincoln Town Car
Our LCD lamp went out on our PT-50LC14 Panasonic, how do we replace it?
It is relatively easy if you are certain that the bulb is burnt out and needs replacement!! I would prefer you read the instruction manual for important information and especially if you have never attempted to do something like this before!! Here is the link to the manual: http://www.fixya.com/support/p232593-panasonic_pt_50lc14_television/manual-7812
If you are 100% certain that you can handle this and you know for a fact that the bulb is bad, the first thing you need to do is turn the power off to the TV. Then wait one minute until the bulb cooling fan stops. You can usually hear it stop! After this has happened unplug the power chord from the outlet.
On the front side of the TV is a long grey panel that is 3 13/16" wide X 34 1/16 inches long. This panel pulls toward you and pops off, with no screws holding it in place.
Behind that grey panel, to the left of center, you will see a white sticker that says " CAUTION:HOT SURFACE". To the upper left of that sticker you will see a black phillips screw that needs to be removed along with the black panel that it holds in place ( black panel approximately 6 9/16" long x 5" high). Once the black panel is removed you will see the front face of another black box with a center grab handle. This is the bulb & housing.....it is an all in one piece and it pulls out directly towards you, once you remove the silver screw on the right side of the bulb housing. Remove this screw first!! You will know you have the correct screw because it has an arrow pointing at it. This screw holds the bulb in place.
Please be careful to pull the bulb out without touching any part of the bulb or bulb housing, as it may still be hot!! Place the new bulb in the same exact way the old bulb was removed and reinstall the silver screw that holds the bulb in it's place. Re-attach the smaller black outer cover, 6 9/16" x 5", and replace the one black screw that holds it in place. Then reinstall the long outer silver panel that covers all of this.
Once installed, please refer to the owners manual for how to reset the hours meter, or you will not have an idea of your replacement bulb life. A quick tip on resetting the hours meter.....the instruction manual tells you to push certain buttons to reset the meter. What they fail to mention is that they are referring to pushing those buttons on the TV set, not on the remote, as is implied, or left to interpretation. When resetting the hours meter, certain commands require pressing buttons on the remote and certain commands require pushing the buttons on the TV set itself....read carefully!!
I hope this helps someone install their bulb and reset the hours meter without to much trouble!!
Aug 24, 2009 | Panasonic PT-50LC14 50" Rear Projection...
How to replace 1998 Ford Contour headlights (with diagram)
Step 1
Remove your Contour's front grille. You can do this by raising the hood and removing two screws that are located on top of the grille.
Step 2 Remove the headlight assembly. The headlight assembly is held into the front of your Contour by three screws. Two screws will be located on top of the assembly, and one on the bottom.
Step 3 Replace the headlight assembly, if necessary. If you are only changing individual bulbs, make sure you replace the correct bulbs. Each assembly holds three light bulbs, including the bright, dim and turn signal bulbs.
Step4 Replace the headlight assembly and reattach the three screws to hold it in place.
Step5 Replace the front grille of your Contour and the two screws that hold it onto the front of the car.
  • It is usually a good idea to replace bulbs together (in pairs). This will allow the bulbs to wear at the same rate.
  • If you choose to replace only the individual light bulbs, do not touch the new light bulbs. The contact of your skin on the bulbs will cause the light bulbs to burn out much sooner.
Let me know if you have any further questions.
Benjamin
Apr 26, 2009 | 1998 Ford Contour
How do you change the low-beam light bulb on Subaru Tribeca? Cant get the headlight assembly out. Have taken the two screws out, but something else holding lower corner.
I just had to do this and learned the hard way.
First take the battery out.
Second remove the plastic cap covering the low beam bulb
Thirdly there are 2 screws holding a wire tension spring against the bulb. Losen the screw towards the outside of the car (Don't touch the screw closest to the engin).
Once you do this, the bulb will come out and you can replace it.
Jan 14, 2009 | Subaru Tribeca Cars & Trucks
Televison & Video Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
