Question about Asrock 775VM8 Motherboard
Drive agp 8x asrock 775vm800
Prescot 800 ata 133
syedmujahed
  • 158 Answers
SOURCE: CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Posted on Sep 27, 2008
SOURCE: bought agp video card x1550 256mb ddr 2 by visonek not working freezes at bio
hi skinny! that problem is you have a 775VM800 which is only compatible with agp ddr video card not ddr2. you need to buy an adapter with max of 256 bit. here, i'm using inn3D G-force fx 5500ddr 256 (128 bit) and it works perfectly. just e-mail if you have to asks something. coolwayne71623@gmail.com.
God Speed!
Posted on Dec 03, 2008
  • 2692 Answers
SOURCE: vga driver mb asrock 775vm800..
Here iss the link to the Asrock download you requested:
http://www.asrock.com/mb/download.asp?Model=775VM800
Posted on Mar 11, 2009
imfixya
  • 84 Answers
SOURCE: audio controller
http://www.asrock.com/mb/download.asp?Model=K7VM3
here u can download...
Posted on Apr 27, 2009
Schmead10
  • 650 Answers
SOURCE: is there driver for mothetherboard asrock ata 133 for win7
HERE IS THE SITE FOR DRIVERS AND BIOS UPDATE FOR THE ASROCK K7S41GX (http://www.asrock.com.tw/mb/download.asp?Model=K7S41GX&o=All)
Posted on Apr 09, 2010
Compaq presario 1700
be sure that your cables are in the right place or your drive is bad
Sep 14, 2013 | Intel Biostar P4TSE-D2 865 Chipset...
What video cards are compatible with my motherboard i have a 7100 GS palit video card, will it work?
Palit Geforce 7100GS video card has a PCI express interface, which is the standard nowadays. Your ASROCK motherboard has a 4x/8x AGP interface. That video card will not plug into your motherboard. You can use any video card that has an 8x (or 4x) AGP connector, or just use the built-in video that is already on the motherboard.
Nov 29, 2010 | Asrock 775VM800 Motherboard
Is the asrock k7vm2 motherboard easily replace by the k7vm4 asrock. my k7vm2 is dead and replacements are not easy to come by. I'm just looking for a new mother board to hook up to my hard drive and not...
You may be able to just swap out the motherboard for a K7VM4 motherboard but some of the specs are different like the chipset and graphics etc.
K7VM4 specs as follows >>>>
  1. Socket A(462) for AMD processor
  2. VIA® KM400 Chipset
  • ASRock U-COP
  • Hybrid Booster - a safe overclocking feature
  • FSB 333/266/200, DDR 333/266/200
  • Integrated UniChrome 3D Graphic.
  • 1 slot for AGP 8X/4X 1.5V
  • ASROCK I/O - default 4 ready-to-use USB2.0 ports on rear panel, default Game/MIDI port.
  • ATA 133 supported
  • On board default 10/100 LAN and 5.1-Ch Audio.
K7VM2 specs as follows >>>>>>>
  2. VIA® KM266 Chipset
  • ASRock U-COP
  • DDR 266/200
  • Integrated ProSavarage8 3DGraphic.
  • 1 slot for AGP 4X/2X universal.
  • Supports both DDR and SDRAM memory modules to provide you best flexibility and save your cost.
  • ATA 133 supported
  • On board default 10/100LAN and Audio.
As you can see the graphics and chipsets are different although the processor sockets are the same.
This could cause problems if you are going to plug the hard drive to another board but saying that is is possibe and has been done before.
This is a chance you take when you swap out a board for a different motherboard although i suspect that the transition should go smoothly.
A fairly old motherboard like K7VM4 or K7VM2 will not cost that much these days. You will find both motherboards for sale on eBay.
Regards.
May 27, 2010 | Asrock K7VM2 Motherboard
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Is there driver for mothetherboard asrock ata 133 for win7
Nov 25, 2009 | Asrock K7S41GX Motherboard
THERE IS NOT SOUND DISPOSITIVE
THERE IS NOT SOUND DISPOSITIVE on myasrock agp 8x sata ata 133 usb 2.0
Apr 17, 2009 | Compaq Computers & Internet
Bought agp video card x1550 256mb ddr 2 by visonek not working freezes at bio
Hi skinnypim210,
Did you buy the visontek x1550 256 ddr 2 agp 8 x video card your self or is it attached already in the mother board you bought? Coz if you buy the original one, it should be mother board only.
Here are my analysis to your problem:
1. The visontek video card which is agp is not possible to be compatible to *********** board. If you just key in your product online the compatible video card is really PCI video cards. it is really dam video card for now. But may be you can re sell it for those motherboard owners that has agp slots.
2. The speed of the video cards are the same but we are talking here of compatibilities.
I hope you're enlighted. just rate my solution so that I will know if you have solved the problem.
Thank you,
jonags3@mail.com
Oct 14, 2008 | Asrock 775VM800 Motherboard
CPU OR Motherboard
Sep 27, 2008 | Asrock 775VM800 Motherboard
Dont know what vga is supported
u mee agp 8 x? ims ure it if has agp slot 3.0 your ready
Jan 28, 2008 | Asrock 775VM800 Motherboard
Asrock 775VM8 Motherboard Logo
29 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
