Question about Sharp AR-M455N Copier
Reset codes Sharp AR-M455N Grayscale Copier - Sharp AR-M455N Copier
  • 990 Answers
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 257 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
SHARP PRINTER AR-M420u ERROR CODE H5-01 RESET
Sir my mchine take code H3-01 whats meen this code.....?
Aug 12, 2012 | Sharp AR-M455N Copier
Code H5-01 on Sharp AR-M450N. Cleared jam. How do we reset? Thanks
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
Oct 14, 2010 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Sep 05, 2010 | Sharp AR-M455N Copier
Need to download latest printer drivers for Sharp copier AR-M455N
Copy this link to download the driver needed
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 15, 2010 | Sharp AR-M455N Copier
Error code L4 30
Dec 16, 2009 | Sharp AR-M455N Copier
How to fix a sharp ar-m455n error code u2-81
Dec 20, 2008 | Sharp AR-M455N Copier
Sharp AR-M455N Copier Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
