HOW TO LOAD WASHING POWDER IN THE SLOTS in LG INTELLOWASHER
SOURCE: Broken washing machine
My WM1812 has a DE error but it is because the drain motor is done in after two years. Good luck with their authorized reps and getting replacement parts. I have found them to be incompetent and unprofessional. No more LG products for me.
Posted on Jan 10, 2008
SOURCE: LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Posted on Apr 23, 2008
  • 73 Answers
SOURCE: good evening i have had a lg intellowasher front
http://au.lge.com/download/product/-982345149Front_Loader_2004_June.pdf
Please click on the link above.
It is for the Manual for your Washer.
Thanks
Please Rate Me
George
Posted on Apr 29, 2009
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
SOURCE: LG Intellowasher cannot complete spin cycle.
My LG front loader will not drain and is displaying OE
Posted on Mar 14, 2010
Where do I put the soap powder when using my LG Intellowasher
Most just add the powder or liquid direct to the wash drum onto the clothes.
Jul 17, 2015 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
Hi i need an instruction manual for an LG
If you google the brand and model you will get a lot of info and/or a locality where you can request a manual....Good luck.........Nomess
Apr 16, 2010 | LG WD-1041WFH Front Load Washer
Jan 12, 2008 | Washing Machines
LG Intellowasher - CL in led code whats wrong?
had this prob too. took me a while to work out. CL is Child Lock... hold down 'Rince' and 'Prewash' buttons at the same time to unlock.
Jun 08, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
