Question about Creda W100FW Front Load Washer
Where do wires go on creda simplicity w100fw
Can find where water pump wire goes on the power board
dazmaraz
  • 67 Answers
SOURCE: Creda W100FW will not take the powder from dispencer and stops during wash
check water supply is on, also you can get low pressure which can cause this problem you could try tablets. and poss your brushes are worn out
Posted on Mar 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
SOURCE: Creda W100FW Front Load Washer. access to service drain plug?
just changed the bearings on my creda simplicity 1000 w100fw
rebuilt it water going in and out ok, now the washing cycle does not work,plenty clicking noises, any IDEA.
many thanks, John
Posted on Jul 03, 2009
barkencoa
  • 3463 Answers
SOURCE: the hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Posted on Nov 28, 2009
beltronic205
  • 1460 Answers
SOURCE: Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Posted on Apr 08, 2010
My Creda simplicity 1000 washing machine wasn't draining or spinning now there's no power light coming on and does nothing when i turn it on is it un repairable
It could be a lot of different things. Maybe the timer. If you know someone who has a volt meter and knows how to use it. Find you machine with a Google search, look for trouble shoot washing machine timer. That's the way I would do it. You want to look for a open in the electrical system *{the switch} like a broken wire inside the switch. Make sure to unplug the machine first. You won't need the power on for the first tests. A volt meter can be purchased for under $10. and any home repair store or box store.
Dec 14, 2014 | Creda W100FW Front Load Washer
Apr 08, 2010 | Creda W100FW Front Load Washer
Need operating instructions for creda simplicity 1000
laundry.manualsonline.com/manuals/.../creda/w100fw_w120fw_w120vw.html -
Mar 22, 2010 | Creda W100FW Front Load Washer
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Creda W200FW No: 45177606 washing machine have removed the PCB from a Creda W200FW washing machine and lost the info as to which plug goes where. Some are keyed and will only go on one place but some will...
Hi
I will try to help as best I can
  1. double red plug onto1x2 2
  2. double black wire plug onto 1x9 2
  3. blue black wire plug onto 1x11 2
  4. then 6 wire plug onto 1x5 6
This hopefully will solve your problem.
Please rate my solution.
Thanks.
Nov 11, 2009 | Creda W100FW Front Load Washer
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Replace if faulty.
Thankyou.
Feb 09, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
78 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
