Question about Argosy HV358T Audio/Video MP4/MP3/ JPG/DIVX Media Player 3.5" SATA Hard Drive Case w/HDMI - Play Vid... Serial ATA, USB 2.0 Drive Case
My argosy HVRB can't reads any XviD MPEG-4 codec what can I do
Tip
Aunsoft XviD to iPhone 4 Converter - Convert XviD to iPhone 4
How to Put and Play XviD Videos on iPhone 4? <br /><br />Xvid is a MPEG-4 video codec for PC. Its purpose is to compress video in order to allow for faster transmission over computer networks or for more efficient storage on computer disks. Hence, Xvid can somewhat be seen as a ZIP for video. Xvid removes information from video that is not important for human perception in order to achieve very high compression rates while still keeping very good visual quality. <br /><br />However, XviD formats can not play on your Apple's iPhone 4. So If you have a lot of XviD files and want to play on iPhone 4, you should convert them. How to convert and watch XviD video on iPhone 4? This article will show you the way to convert XviD to iPhone 4 for enjoyment with <b>Aunsoft <a href="http://www.aunsoft.com/video-converter/">iPhone 4 Video Converter</a></b> (For Mac User: Aunsoft iPhone 4 Converter for Mac). And the whole process of XviD to iPhone 4 converting is as easy as pie for you. <br /><br />Step-by-step Guide: How to Play XviD Videos on iPhone 4? <br />Step1: Download and install <b>Aunsoft <a href="http://download.aunsoft.com/video_converter/videoconverter_setup.exe">XviD to iPhone 4 Converter</a></b>. <br />It is a very safe and 100 % clean software and works very well for iPhone 4. So just run it. <br /><br />Step2: Load videos to this iPhone 4 video converter. Click "Add" button to load your XviD files to this best iPhone 4 video converter. <br /><br />Step3: Select output format for your iPhone 4. Here you can select "iPhone 4 MPEG-4 640*480 (*.mp4) or iPhone 4 H.264 720P (*.mp4)" as output video for iPhone 4. <br /><br />Step4: Start converting your XviD videos to iPhone 4 by hitting the "Convert" button. <br /><br />After conversion, please connect your iPhone 4 to PC and transfer those converted MP4 video to your iPhone 4 via iTunes. Then, you can enjoy and <b><a href="http://www.aunsoft.com/top_xvid_to_iphone4_converter_convert_xvid_to_iphone4/">play XviD on iPhone 4</a></b>.
on Jun 24, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
My Blu-Ray Ripper Reveiws Okay so I spent hours playing with different options...
My Blu-Ray Ripper Reveiws <br /><br />Okay so I spent hours playing with different options for ripping blu-rays into a format that could be transferred to my Xoom and I would like to share what I have learned. <br /><br /><br />The Rippers <br />I started with some research and downloaded six or seven different programs designed for ripping blu-rays that were recommended some where on the web. <br /><br />I almost immediately discarded all but three rippers. Two were immediately ruled out after just examining the UI and noticing the lack of customization options. Another three were ruled out based on the fact they required a separate program called AnyDVD to run at all. This didn't bother me too much but further investigation found that AnyDVD costs $60+ in itself and does not offer the most user friendly experience. <br /><br />It's also worth noting I did not try out the beta of DVD Catalyst because it also requires AnyDVD or a similar program running in unison both of which would be added cost and added hassle. If your only looking to rip DVDs then DVD Catalyst for only $10 is the way to go from what I hear. <br /><br />What I ended up with were three blu-ray ripping trials. <br />DVDFab <a href="http://www.bluray3dripper.net/DVDFab-Blu-ray-Ripper.html">Blu-ray Ripper</a> - $60 <br />Pavtube <a href="http://wannasoft.com/Pavtube-Blu-Ray-Ripper/">Blu-Ray Ripper</a> - $49 <br />Aunsoft <a href="http://www.bluray3dripper.net/Aunsoft-Blu-ray-Ripper-for-Mac.html">Blu-Ray Ripper</a> - $49 <br /><br /><br />At first glance Pavtube and Aunsoft seemed almost identical in UI but they performed very different. <br /><br /><br /><b>Customization</b> <br />DVDFab was the first ripper I tried and I was very disappointed with the lack of control when ripping the blu-rays. There were nine different profiles to choose from when selecting .mp4 output format. Five of which had either 'ipad' or 'iphone' in the name and had very low max resolution outputs. In the end the only profile that was workable was the basic profile for h264 and for some reason did not support 1920x1080 resolution. <br /><br />Pavtube and Aunsoft had, like I mentioned, identical UIs and actually shared identical customization options. In addition to having many more built in profiles for everything from different Android phones and IPhones to gaming consoles and even power points, it also had basic profiles for common video formats. <br /><br />Where both Pavtube and Aunsoft set themselves apart from DVDFab was in the customization of these profiles. While DVDFab attempted to give me control of resolution, frame rate, bit rate, and audio, Pavtube and Aunsoft actually allowed me to change these to an assortment of options including 1920x1080 at multiple frame rates. <br /><br /><br /><b>Testing</b> <br />In order to get a good base line of these programs I popped in Avatar on blu-ray into my blu-ray rom and selected a chapter to use as testing so I didn't need to rip the entire movie every time. <br /><br />From here on you will see me post settings in the form: <br />Codec: [codec used, file type always .mp4] <br />Resolution: [resolution] <br />Bit Rate: [bit rate] <br />Size: [file size generated] <br />Speed: [time it took to rip, in minutes] <br /><br />In DVDFab I was only able to make one good base test due to the lack of customization. I set the settings to: <br />Codec: h264 <br />Resolution: 1680x946 <br />Bit Rate: 5000 <br />Size: 130mb <br />Speed: 9:33 <br /><br />This test led me to believe that DVDFab was a possibility because the picture looked phenomenal with good 3d depth and very little artifacting around moving objects. The problem was that it was laggy. It took 10-15 seconds for what appeared to be buffering before the clip would smooth out and then I would get bullet lag quiet often. <br /><br />I was confident this would be improved if I played with the settings but found that quality had to really be reduced in order for the clip to smooth out. <br /><br />DVDFab was essentially ruled out. <br /><br />I then put together some test batches for both Pavtube and Aunsoft. I chose to go with four different profiles for each program. h264 with HD standards, h264 base standards, MPEG 4 (xvid) with HD standards, and MPEG 4 (xvid) with base standards. These were the final settings and results: <br /><br />Note: The chapter I chose was 3:34 long and my computer is using an Nvidia GTX 570 paired with an Intel E6750 2.66GHz dual core processor. You can use this information to judge the speed it took to rip these files. CUDA acceleration was on for all but the first video, CUDA is an Nvidia technology that speeds up the encoding and decoding of h264 files which is the reason the h264 files were significantly faster than the xvid files. <br /><br />PavTube <br />4 files <br /><br />Codec: h264 HD <br />Resolution: 1920x1080 <br />Bit Rate: 9000 <br />Size: 230mb <br />Speed: 12:57 (CUDA acceleration was off) <br /><br />Codec: MPEG(xvid) HD <br />Resolution: 1920x1080 <br />Bit Rate: 12000 <br />Size: 307mb <br />Speed: 8:40 <br /><br />Codec: h264 <br />Resolution: 1920x1080 <br />Bit Rate: 9000 <br />Size: 232mb <br />Speed: 3:20 <br /><br />Codec: MPEG(xvid) <br />Resolution: 1920x1080 <br />Bit Rate: 12000 <br />Size: 307mb <br />Speed: 8:40 <br /><br /><br />Aunsoft <br />4 files <br /><br />Codec: h264 HD <br />Resolution: 1920x1080 <br />Bit Rate: 9000 <br />Size: 232mb <br />Speed: 3:19 <br /><br />Codec: MPEG(xvid) HD <br />Resolution: 1920x1080 <br />Bit Rate: 12000 <br />Size: 307mb <br />Speed: 8:40 <br /><br />Codec: h264 <br />Resolution: 1920x1080 <br />Bit Rate: 9000 <br />Size: 232mb <br />Speed: 3:20 <br /><br />Codec: MPEG(xvid) <br />Resolution: 1920x1080 <br />Bit Rate: 12000 <br />Size: 307mb <br />Speed: 8:47 <br /><br />As you can see the file sizes and speeds were almost identical between Aunsoft and Pavtube. Except of course for the first one where I forgot to turn CUDA acceleration on for the ripping. <br /><br /><br /><b>Quality</b> <br />Now here is where it got difficult. I know right off the bat people would ask me why I even tried the xvid codecs and instead just accepted that h264 would be the better codec. But I actually found the quality of the xvid looked better than the h264. After watching these clips over and over again both on the Xoom and hooked up to my HD TV, I settled on either the h264 with the HD standard and the xvid with the base line standards. Don't ask me why these two because I couldn't tell ya. <br /><br />I like to think I have a pretty good eye for video quality, I currently sell HD TVs and can see the difference between 100k contrast and 120k contrast if that gives me any sort of justificaton. <br /><br />I eventually agreed (with my girlfriend who was helping me judge) that the MPEG 4 with the xvid codec ripped by Pavtube was the best quality of the bunch. The colors were much more vibrant on my 42 inch plasma while the edges of moving objects were not blurred at all. <br /><br /><br /><b>Results</b> <br />What was important to me: <br />Quality of the Video <br />Compatibility with the Xoom <br />Usability of the program <br /><br />What was not important to me: <br />Time to rip (I'm happy doing one movie overnight every night if need be) <br />Size - to an extent (quality is more important) <br /><br />After reviewing every aspect of these programs that was important to me I can honestly say that Pavtube gave the best quality and also the best user experience. The reason it beat out Aunsoft is the fact that Aunsoft would convert some of my videos (the ones with the HD standards) to a 4:3 aspect ratio and also four tests made by Aunsoft failed to load on the Xoom while only one Pavtube test failed to load. <br /><br />So I will now begin ripping my entire blu-ray collection into MPEG 4 formats at 12000 bit rate. But note at these settings your probably looking at 10GBs per movie so these settings are for people who share what is and isn't important for me. Even if this is not what your looking for I would still recommend Pavtube as the ripper of choice but instead of the xvid codec at 12000 bit rate I would go with the h264 codec at 9000 bit rate because you won't sacrifice clarity, just color. <br /><br /><br /><b>Tips</b> <br />If you are looking to test video quality for yourself look for a chapter when under Title Mode (on the Pavtube UI) that is rather short but has a good display of colorful moving objects and rip that chapter into different formats and settings. <br /><br />When ripping the full movie switch the UI to File Mode and rip only the main file. The reason I recommend switching to File Mode is because if you rip both the title and all the chapters under Title Mode it will actually rip the movie twice. If you read my previous edits you will have seen how this doubled my file size. <br /><br />Manually set the frame rate to what your looking for, I recommend matching the source. But do not use original frame rate when ripping the full movie, for me it got it wrong and played my movie in what appeared to be fast forward. <br /><br /><br /><br /><b>Epilogue</b> <br />I need to note that I'm in no way affiliated with any of the above programs and did this testing because I couldn't find any reviews that were not sponsored by the programs themselves. <br /><br />I'm entirely new to compression and ripping so this was a learning experience for me and hope that my terminology and assumptions of how the process works is accurate. <br /><br />As a CS major I'm looking to get familiar with technical writing and I hope this review was readable, informative, and to the point. <br /><br />Everything above is simply my opinions based on the time I spent with these programs
on May 21, 2011 | Computers & Internet
Unsupported video file
Any video file that is .avi requires codecs. Most players don't have a comprehensive list of codecs on their chips though they have divx and xvid on many devices these days. divx and xvid are codec types of .avi. Types such as .mpg or .mpeg or mp3 or mp4 are older and more compatible with most equipment. mkv may not work
Oct 16, 2013 | Kenwood Car Audio & Video
Please tell me where can I get video converter for Multi codec jukebox Iriver h320
Unfortunately, your H320 is great for music, but quite limited when it comes to video files.
The video format specs for Iriver H320 are:
File format: AVI
Codec: XviD MPEG4 (recommend XviD 1.0.2 codec)
Resolution: 220 x 176 only
Frame Rate: 10 or 15fps
Bit Rate: 500Kbps or less
Audio Codec : MPEG 1/2/2.5 Layer3
Audio Bit Rate : 128Kbps, 44.1KHz, CBR
For video conversion, try Pazera's Video Suite or NCH Prism Video Converter; both are freeware.
Sep 08, 2013 | iRiver H340 MP3 Player
Tip
Convert XviD to iPhone 4-Aunsoft XviD to iPhone 4 Converter Xvid is a MPEG-4...
However, XviD formats can not play on your Apple's iPhone 4. So If you have a lot of XviD files and want to play on iPhone 4, you should convert them. How to convert and watch XviD video on iPhone 4? This article will show you the way to convert XviD to iPhone 4 for enjoyment with Aunsoft iPhone 4 Video Converter (For Mac User: Aunsoft iPhone 4 Converter for Mac). And the whole process of XviD to iPhone 4 converting is as easy as pie for you.
Step1: Download and install Aunsoft XviD to iPhone 4 Converter.
After conversion, please connect your iPhone 4 to PC and transfer those converted MP4 video to your iPhone 4 via iTunes. Then, you can enjoy and play XviD on iPhone 4.
on Jul 17, 2010 | Cell Phones
Best quality USB multimedia playback format for the neoniq 21.5" tv
mpeg 4 is Hi def. If you record 1080p then it will play back in Hi def.
Apr 20, 2013 | Sharp Aquos Televison & Video
Video'o are half screen
Click "Start," "All Programs" and double-click "Windows Movie Maker" to open the application. Click "Tools," "Options" to open the "Options" dialogue box. Click the "Compatibilty" tab and locate "Xvid MPEG-4 Video Decoder." Remove the check next to "Xvid MPEG-4 Video Decoder" and click "OK" to disable it.
Feb 02, 2013 | iMesh
XVID MPEG-4 (XVID)
you can download the latest codec of xvid for playing xvid codec movie go to this address
http://downloads.xvid.org/downloads/xvidcore-1.3.0-rc1.tar.gz
or
http://www.xvid.org/Downloads.43.0.html
step1: Install it your pc
step2: restart your PC
Jan 12, 2011 | Computers & Internet
Where can I get XVID MPEG-4 (XVID) codec
Please try downloading them from the link below:
http://www.xvid.org/Home-of-the-Xvid-Codec.1.0.html
Regards,
Rashish
Aug 11, 2010 | Computers & Internet
Argosy HV358T Audio/Video MP4/MP3/ JPG/DIVX Media Player 3.5" SATA Hard Drive Case w/HDMI - Play Vid...  Serial ATA, USB 2.0 Drive Case Logo
90 people viewed this question
Top Argosy Computers & Internet Experts
David Payne
David Payne
Are you an Argosy Computer and Internet Expert? Answer questions, earn points and help others
