Question about Sansui DTV2760 27" TV
Bad sound-garbled and goes off on certain channels.
I bought a Sansui dtv2798 27" and some of the stations -channels have static and the sound goes off. Usually when I change from channel 151, for instance, to 154 tha sound comes back. The words are partial and garbled sometimes.
  • jcadla Oct 28, 2008
    It turned out to be the Dish receiver. I decided to go over everything connected to the TV and found the same thing happened on another TV when I connected it to the same cable. I reset the receiver,-unplugged it for a while-ten minutes- and the trouble went away. Thanks for your suggestion. Jim
  • Sansui Master
  • 520 Answers
Go into the menu and make sure the SAP is off.
Posted on Oct 28, 2008
VOLUME WILL NOT WORK ON CERTAIN CHANNELS ON MY SANSUI TELEVISON
Make a hard reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it back after 3 minutes or so. This must rectify your TVs problem.
Nov 14, 2012 | Sansui Televison & Video
Sansui au-999 static right speaker then blows right speaker fuse
so meaning the right speaker needs a filter which frequency is it normaly u using a certain yf for a certain type of speakers and if you dont the fuse or what ever will go
Apr 15, 2012 | Audio Players & Recorders
Sound is garbled on one channel only-using antenna.
Try using a different antenna or moving the antenna to a different ocation. if none of that works you might have a bad signal board. You can get parts at www.interliquidparts.com
Dec 12, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
My tv have roaring sound in certain channels.What is the cause of this?
Not the tv problems,this problems are the tv stations channels broadcasting tv stations,it is the problems of the tv stations.Some tv broadcasting stations channels are roaring sound some are normal or smaller.Just use the tv volume control + - adjust the tv suomd that all.
May 12, 2011 | Samsung HL-P6163W 61" TV
Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Mar 26, 2010 | Audio Players & Recorders
Our 37" series 4 (450) LCD TV sound "garbles"
Hi my name is Roety,
I can help you with your issue ,
Make sure you have the latest firmware upgrade from Samsungs website!
Also weak signal can cause this if using air signal raise or connect a better antenna
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 29, 2009 | Samsung LA37A450 37 in. HD-Ready LCD TV
How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Jun 05, 2009 | Sansui 19 in. LCD TV
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Sansui DTV2760 27" TV Logo
151 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
