Question about Dryers
MANUAL FOR SIMPSON MAXIDRY 1000P
MODEL 1000p
4 Suggested Answers
  • 3074 Answers
SOURCE: require electrical schematic diagram for simpson
http://www.tpub.com/content/construction/14026/css/14026_214.htm
Posted on Nov 28, 2010
  • 99 Answers
SOURCE: Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Posted on Aug 03, 2009
SOURCE: How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Posted on Jan 04, 2010
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
I have a green light and orange light on my dash indicating which mode its in (city/highwsay). which is which?
Just remember that "green means go" as in, you are on the highway at a higher rate of speed and need maximum range from your system.
Amber is the "city" mode and reduces the sensitivity of the unit for when you are in the city or congested traffic.
Aug 14, 2011 | 1000P Radar Detector
No power to motor checked continuity of main switch the door microswitch is brand new and has continuity so to has the spring loaded idler circuit breaker switch, dryer was running after pulled down and...
I know you have already checked but first things first: breaker is not tripped, have 220 volts at outlet, have 220 volts at terminal lugs of dryer, if yes to all then some motors have a switch on the motor, do not know if yours will, it is where the power plugs into the motor, one is a trip the other a reset. Now we get into the other aspects of why dryers will not start, since the door switch is eliminated, then it is on to the others, here is a website that will help, now if all checks good feel free to post, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 28, 2010 | Dryers
I have a MX1000 tripod. The head has part#MX-1000P. I'm unable to find this quick release camera plate anywhere. Can you help? Thanks, Ms. Purdy
This Tripod was made in China and distributed by a company in GEorgia called OSN. I have one and need a part also.
the email on the box is osn@bellsouth.net I have not tried to contact them yet
web site is http://www.osnusa.net/
Oct 21, 2010 | Cameras
Hi guys got a simpson maxidry 1000p dryer problem is that it has no heat is it stuffed or can it be fixed
Well first of all you may check out the Heating element - If a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter (volt meter). No continuity means the element is bad and you need to replace it (electric heating element not repairable) further you may check the Thermal fuse - A thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse, which is about an inch long, usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. And the last dought goes on the Wiring - you need to deep inspect the wiring in your dryer and check for any burnt sign.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Dryers
WHat size battery goes in a SmartLink SLP-1000P
corli, You will need to disconnect the SLP-1000P and open unit to find out the name and model number (battery number) of the batteries used in this unit. The company that made this UPS backup supply is no longer in business. Good luck. 12fixlouie
Mar 13, 2010 | Smartlink Computers & Internet
Dryers Logo
1,170 people viewed this question
Top Dryers Experts
