Question about Maytag MBB2256GES Bottom Freezer Refrigerator
Freezer is OK. Refrigerator is 45 degrees
If I leave the door closed, It can get to 40 degrees F. but no lower. The noises sound normal. Cycles on and off. No ice buildup that I can see. A few ice droplets on the temp knob in the freezer. We had a 2 hour power failure last week.
  • 29 Answers
Why did the power fail? I had a refrigerator blow both its computer boards by a power failure.
However, there is a procedure for fixing a frig. Most likely the defrost heater is not working. (Your situation sounds like it might be something else.)
On the back wall of the freezer are the cooling tubes. These must get very cold and frost up with time. There is no such thing as a "frost free" refrigerator. All coils frost up. What actually happens in a "frost free" refrigerator is that every so often the refrigerator part shuts off for a while and a heater turns on to heat the coils to remove the frost. This frost turns to water and drains out the back to a sump outside the refrigerator. What usually happens is the heater burns out. Sometimes the timer stops if it is a motor driven timer and sometimes the computer fails if it is computer driven.
If the coils freeze solid with ice the air cannot circulate through the back tubes and into the refrigerator section so will give you exactly your problem.
The easiest way to do this is to take all of the food out of both parts of the refrigerator. You need about two days to fix this. Unplug the frig. Pull it forward. Look at how much water is in the pan under the refrigerator. Leave both doors open for two days. Then look at how much water is in the pan. It should be FULL or Overflowing. This means that the coils were frosted up. If it is empty then this means that the tube to the pan is plugged. If it is only half full then this means everything is good and it most likely the circulatory fan which is in the refrigerator portion.
If the tube is clogged the easiest way to clear it is to hook a wet vac up to it and suck it clear. You can push a plastic line up through the tube but this may bend the fins or break the heater that are located in the freezer. I use a weed eater line for this.
Most likely it is the heater element that is out. These are standard replacement items and most appliance repair shops have them. You cannot change these until the ice is all melted and using a hair dryer takes a long time. It is easier to just wait the two days.
If you have an automatic ice machine in the freezer this must be removed before the back panel can be removed.
Good luck.
Posted on May 08, 2014
5 Suggested Answers
hemantraj
  • 638 Answers
SOURCE: refrigerator not cold enough
check the ventilations my friend
Posted on Jun 15, 2008
  • 198 Answers
SOURCE: freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Posted on Jan 09, 2009
  • 9 Answers
SOURCE: Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Posted on Jan 10, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator and freezer are warm
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 03, 2010
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
Refrig door was not completely shut fof about 24 hrs temp was 50. Makes a loud noise when running and about 8 hrs after discovery has only gone to 46 degree
Listen to sound where is it coming from bottom back? Or inside near back wall . noise could be ice on or around evaporator fan if you can unplug for 12 hours leave doors open this will melt ice . if it is ice that will fix it.
May 08, 2015 | Gladiator GAFZ21XXMK Bottom Freezer...
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
Our new KitchenAid side by side refrigerator makes a knocking noise after you close either freezer or refrigerator door. We haven't fully installed the ice maker yet, so I know it's not...
The knocking noises heard from the Freon moving through the sealed system are perfectly normal and usually do not last long. Since the evaporator coil is mounted in the freezer section, the noise is usually louder there. Some people say it sounds like marbles knocking together.
Nov 08, 2012 | KitchenAid KSRS25MWMS 25.0 cu. ft. Side by...
Samsung RF26XAEBP frig a little over 2 years old sounds like fan motor is rubbing behind icemaker area when i open the door it stops close the door it starts again how to resolve?
You need to unplug and then remove the rear panel inside the back of the freezer and look over the fan assemblies to insure they are not hitting accumulated ice. Ice buildup around fans can be caused by leaving refrigerator or freezer door open over extended times or defrost component failure. Either way it's a good idea to have a look at the inside of the evaporator compartment to prevent damage to fan blades and food loss. Click HERE FOR=>> Samsung Refrigerator Model RF26XAEBP Parts I will be here if you have questions, Thanks Sea Breeze
Jul 03, 2012 | Samsung RF26XAEBP
Coleman electric cooler fan keeps locking up
This is a common problem with these coolers.
Could be the fan needs to be lubed. Pull the covers off, take the fans off, pull the stickers off the fan and put some light grease in the small hole. Put back together and try it.
BE CAREFUL WITH THE FANS, you can break the blades very easy
Apr 06, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Skybox will nat cool below 40 degrees
The likely cause is a heavy frost and ice buildup on the internal evaporator plate behind the dispensing unit. Unplug the unit and open the door for 24 hours. Plug the unit back in, reset the thermostat to the 11:00 position.
Jun 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Open Questions:
See all Maytag MBB2256GES Bottom Freezer Refrigerator Questions
Maytag MBB2256GES Bottom Freezer Refrigerator Logo
116 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
