Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
I have two arrows flashing on my cadet 1000 series LT 1042 is this a problem or is it normal
Bought mower second hand a year ago and dont have manual, the two arrows are pointing towards each other and is in the left hand side of the display. Mower starts and runs okay, but I have never noticed this message flashing before, it was getting low on oil which I have since topped up.
  • 551 Answers
SOURCE: I need an owners manual for a cub cadet riding
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Posted on Mar 31, 2009
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: I have a cub cadet mower and it has the hydrostat
There are two belts - the main drive belt from the engine to the hydrostatic transmission, and the mower belt that runs from the engine to the mower deck. Sounds like the main drive belt broke or came off. It's not an easy job to replace because it's up against the chassis underneath, and you usually have to remove and replace some parts to get at it. Take a look under there, see if the belt's gone, and decide if you want to tackle it or have a shop do it.
Posted on Jun 12, 2010
  • 146 Answers
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Posted on Jul 10, 2010
roadtech7
  • 297 Answers
SOURCE: I have a 2006 Cub Cadet RZT 42 Zero Turn Mower
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
Posted on Nov 03, 2010
Testimonial: "roadtech7 was SUPER helpful and very patient. A very knowledgeable tech. Thank for all the help pardoner! "
Where is the spark plug on a cub cadet 1040lt
OPen the hood and you will see it. Link to owner's manual at cub cadet. see page 21: http://www.cubcadet.info/Manuels/2007/1000-SERIES-LT/OWNERS/LT1040_13AX10CG710_Ow_07.pdf
Jul 26, 2014 | Cub Cadet Garden
White smoke comes from front of the mower when you first start the engine.
It just take a couple of starts to disappear - of course, if you removed all the creepers from inside
Aug 07, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Need a manual for craftsman lxt 1000 riding mower bought back four years ago
no manual but can i help you threw the problem your having?
May 27, 2012 | Craftsman Garden
Steering problems on our 2005 Cub Cadet LT 1042
Your looking at a new steering gears at the bottom of the shaft. You can fix it if you have the time. You need to hoist the front end into the air....drop the deck, remove the nut on the steering wheel and everything pulls out the bottom of the machine.
If your not handy....send it to a good repair shop. www.nnyparts.com
May 29, 2010 | Garden
I have a Cub Cadet LT 1024 Series 1000 riding mower. It has been starting hard and it is not the battery. Now it tried to start and when I tried a second time to start it there was no sound at all. I'm...
Try lifting the hood on the mower and turning the flywheel, back & forth by hand, this will release the starter gear from the flywheel.
It could be the starter, but I would load test the battery first.
Apr 14, 2009 | Garden
I need an owners manual for a cub cadet riding mower. series 1000. model 1042 Lt. serial # 3430203833. thank you
Mar 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
102 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
