Question about HP Photosmart D7460 Printer
Printer does not have enough ink to ensure printer health
adonscott
  • 106 Answers
SOURCE: connot print
There are several factors that contributes that certain error message. try the following steps.
Performing a semi-full reset of the All-in-One. Remember, make sure that you follow the steps exactly.
  1. Make sure that the printer is TURN ON.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
  7. Note: if the issue is still not resolve, please let me know.
Best regards
adonscott
Posted on Jul 03, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print in color - HP C6180
hi,
below is the document that i would like you to follow. If still the document wont resolve your issue, please call 1-800-474-6836 for tech support. Also, check the warranty of the printer, and if the tech found out that its an ink problem, then they can go ahead and have it replace.
CLICK HERE ==>> DOCUMENT
thank you.
adonscott
Posted on Sep 09, 2008
  • 67 Answers
SOURCE: I have replaced ink cartridge that was low but it
Press the left arrow and the setup button together..
You will find Support Menu.. press the arrow key to come to Prit test menu.. click ok on that ..
now, press the arrow button to choose Nozzle test..
even after that if it continues to show the error, and if you are not able to print anything from the computer..
You may try by doing a L2 uninstall and then reinstall ..
Posted on Aug 12, 2010
SOURCE: cannot print in black because yellow cartridge is empty ?
Take the "empty" cartridge out and shake it, and then reinsert it. I did that on my HP 8500 and it worked. The indicator light showed it was full.
Posted on Nov 01, 2010
  • 352 Answers
SOURCE: I am getting a error
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Posted on Apr 14, 2011
Need help in fixing HP Photosmart C5280 Printer two springs on the side of carriage bar
We suggest you contact 'Parts Here' as they provide most parts for the C5280 printer, including carriage assembly parts, along with the C5280 service manual: http://www.partshere.com/models/hpprinters.asp?printer=Q8330A
C5280 CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding - refer to Inkjet411's support page: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
NOTE: If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Oct 15, 2014 | HP Photosmart C5280 Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have replaced ink cartridge that was low but it still will not work ,keeps telling me that I need a new cartridge.Saying printer does not have enough ink to ensure printer health. The empty ink cartridge...
Aug 12, 2010 | HP Photosmart C5180 All-In-One InkJet...
Replaced ink cartridge and printer still says "replace ink cartridge"
Try to ensure that all points of contact for the ink cartridge and the printer are clean.
If you have a compressed air canister, then use it gently to blow all paper dust out of the insides of the printer. Paper dust can block the photoelectric cells, which determine contact between parts of printers.
If there is just enough dust, it will stop the printer from functioning properly.
-a.
Nov 23, 2009 | HP Office Equipment & Supplies
My C6180 is telling me 'Cannot print - printer does not have enough ink to ensure printer health' However when I press the arrow for more information it does not tell me which cartridge requires...
If you enable the Canon Printer Status Monitor you can see the true state of all the cartridges in the printer and can easily see which one needs replacing. You can also see this when you carryout a nozzle check and can also reach this by going to Control Panel - Printers - [Select your Canon Printer] – right click and select Properties - Maintenance - View Printer Status
Oct 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Sep 12, 2008 | HP - HP Photosmart 8250 printer
hi,
thank you.
adonscott
Sep 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
Connot print
Best regards
adonscott
Jun 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D7460 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
