Problem with AEG Lavamat 50430 front loader washing machine
My washing machine wouldn't spin nor pump out. Replaced brushes but still not spinning nor pumping out. How do I get access to the pump and hoses to check fro blockages or ultimately replace pump?
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Posted on Apr 26, 2008
  • 1462 Answers
SOURCE: Random red stains appearing on
possible you have some red clothing in the gap between the tub and drum - there is nothing in the machine to cause red stains
to check, remove rear half of cabinet, remove heater (held by 1 10mm nut which just loosen and prize out heater) you can then see into the gap between tub and drum. shine in a torch and rotate drum by hand to see if you can spot anything. disconnect from mains first
Posted on Jul 23, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
I have a aeg 72360 update washing machine and it keeps stopping and coming up E20. It will not spin
make sure the drain pump is operating correctly or if so, check the motor brushes.
Aug 09, 2010 | AEG Lavamat 72640 Front Load Washer
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
PUMP PROBLEM
The problem you have can be caused by something inside.. clothes blocking the outwater, or metal or something blocking the pump.. soulution: clean it..... Take away gum (the gum betwin pump and machin). Clean/take awway clothes and etc from inside... there can also be something in the gum... check it! and check the pump to.
Jan 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
