Question about Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz / 1GB DDR / 200GB HDD / DVDRW DL / DVD-Rom / Flash PC Desktop
No Video Signal
The monitor for my Gateway GT5228 suddenly has "no signal" and then goes into standby. This occured after one year of the computer and monitor working perfectly. I tried hooking up a different monitor and video cable to the computer with the same results. I assumed the onboard video card had gone bad so I purchased a Radeon HD 3650 (PCI express) and put it in the PCI slot and connected the monitor to the new video card...same results. How can I get a video signal from my computer? When I start my computer I do not get a signal to my monitor. Just get a blank screen. I put on a new cable but get the same result. I hooked my monitor up to a different computer and it worked on the other computer. What should I try next?
  • 2 more comments
  • Anonymous Oct 25, 2008
    Same thing here. This morning my PC just started doing the same thing, I got a new graphics card and did pretty much all you did, still nothing.
  • debster45166 Oct 31, 2008
    No it does not beep! All I here is the fan running!
  • debster45166 Nov 03, 2008
    Thanks for trying but resetting the bios did not work!
  • Debs
    Debs May 11, 2010
    It doesn't sound like the monitor. It could be bad bios. When you turn on the computer does it beep to let you know that it has booted okay?
  • 903 Answers
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Posted on Oct 31, 2008
  • Debs
    Debs Nov 03, 2008
    Have you tried starting your computer in safe mode, incase it is a driver conflict. When you turn the computer on continuosly press F8 and if the screen does display click on start in safe mode. This will by pass any drivers that you have for your graphics card and use the generic one. Try this and get back to me
  • Debs
    Debs Nov 04, 2008
    if you have onboard graphics you can also take out any graphics card that you have inserted i.e. pci or agp and the boot to determine if you have a faulty graphics card. If you have onboard graphics it will boot to the monitor have you tried this?
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Mar 27, 2013 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Monitor says NO signal...can hear the computer boot up and make its' welcome to windows noise, but the montior goes into standby after saying NO signal
you must make sure that the VGA cable to the computer is properly fitted to the sys unit. if problem persist pls add a VGA card to your sys unit to solve your problem rate solution Afterwards
Jan 04, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Cant get pci video to work
Download the MANUAL for the GATEWAY website to see how to diasable the "onboard" card.
Jan 18, 2009 | Gateway (4000594) Motherboard
Signal to monitor goes in and out, mostly out
Hopefully, it is just the on board video that has gone bad, and not the motherboard. When you install a video card on a PC, that has on board or integrated video, you will need to access the BIOS screen on start up and disable the on board video. That way the video signal will come from the new video card and not the on board video.
I hope this helps,
Jan 18, 2009 | Gateway GT5220 PC Desktop
Gateway FPD1760TFT LCD monitor
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Monitor stays in standby from startup
Try it on a different computer. Standy usually indicates not getting a signal from the video card and then it goes into standy. If it works on a different machine or laptop, check your video card.
May 26, 2008 | IBM T 750 17" LCD Monitor
No Video Signal
reboot in safe mode, safe mode will put the pc in vga mode and use whatever video it can find.
If no good U may have a problem with the MB.
May 23, 2008 | Gateway GT5228 PC Desktop
Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz / 1GB DDR / 200GB HDD / DVDRW DL / DVD-Rom / Flash PC Desktop Logo
371 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
