Question about Toys
How to change a massey ferguson tracto 35 diesel fuel filter
  • 165 Answers
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Posted on Feb 27, 2010
SOURCE: MF Tractor 265 diesel engine fuel problems.
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
Posted on May 29, 2010
roniecon
  • 6927 Answers
SOURCE: I have a TO-35 Massey
The only thing left to check is the timing,and the fuel,make sure there is no contamination in the fuel ,and no water,try a cleaner,and a dryer for the fuel.It does sound more like the fuel.
Posted on Aug 17, 2010
  • 335 Answers
SOURCE: 35 gas massey ferguson tractor new carb,new
If you're not having any electrical issues then Check the governor.
Posted on Aug 13, 2011
  • 5655 Answers
SOURCE: 1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
Posted on Oct 03, 2011
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
Looking for wiring diagram for a Massey Ferguson 35 with 3 cylinder perkins diseal
You might look through these images:
https://www.google.com/search?q=1961+Massey+Ferguson+35+wiring+diagram&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Feb 18, 2018 | Toys
Ferguson tractor misfiring
fe 35 23c engine,the diesel feed pipe to the heater plug still drips fuel in the inlet manifold when runnig causing it to splutter is this normal.
Jan 16, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
May 15, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Massey Ferguson 35 has no spark, I have replaced the coil, what could be the problem?
Feb 26, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
What kind of oil goes in a Massey Ferguson Tractor gearbox?
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Jul 18, 2009 | Puzzle Massey Ferguson Tractor
Toys Logo
282 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
