Question about Roper REX4634KQ Electric Dryer
4 prong to 3 prong
With the 4 prong wire there is a green wire from the plug and from the dryer screwed to the housing. when hooking up the 3 prong wire what do you do with the green wire from the dryer
    Genius:
  • 1,028 Answers
Connect green wire back to cabinet rear at green screw..in a 4 wire hookup the green wire from the dryer was supposed to be either cut off or attached back to neutral(center screw)
Posted on Oct 25, 2008
My new dryer came with a 4 prong plug. Due to the age and construction of the house It was recommended to buy a 3 prong dryer pigtail and "run a jumper " in the back of the dryer for the...
This is where the difference between 'ground' and 'neutral' comes in. 'Ground' runs only to ground, while 'neutral' may be tied to ground but it must be tied to the power company's neutral line. Using one for the other is a common cause of 'stray voltage'.
If you look on the back of the machine where the other wires come out you should find a green screw attached to the cabinet. Running a jumper wire from this screw to a proper ground will make the machine safe to touch under conditions such as failure of insulation in the machine, leaking water, you without your rubber boots, especially all of them together.
The box you're plugging into should be properly grounded. If it is, then just hook your jumper to it- you will likely fine another green screw for grounding inside that box.
lp
Jan 05, 2011 | Whirlpool W10182829RB 3Wire Electric Dryer...
Hook up a 4 prong plug in the back of a 3 prong series 90 dryer. What wire go to which screw?
white in the middle,red on one side black on the other just like the three prong and the green just has to be grounded to the back of the dryer,remove a screw close to the block as long as the wire reaches and connect the ground wire or green wire to the screw and screw it back in
Mar 20, 2010 | Kenmore Dryers
I moved into a house that has the 4 prong dryer receptacle and I bought the new 4 prong plug to hook up to my dryer but there are only 3 wires on my old one. The new one has a red, green, white and a black...
be careful the voltage may be different thats why they make them with different plug configurations. check your dryer voltage requirement. usually the four wire type are for 250vac electric dryers.
Mar 06, 2010 | Dryers
Need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
May 06, 2009 | Kenmore 62602 Electric Dryer
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Roper REX4634KQ Electric Dryer Logo
122 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
