Question about Panasonic Panafax UF-880 Plain Paper Laser Fax
Gray line down middle of faxes/copies on panafax uf880
My fax machine/copier is printing a gray blurry area down the middle of each page. The area is about 3.5 inches across, and some the print inside the area shows white in contrast to the gray, so I can kinda read some areas. Is this a toner problem?
  • vpw519 Apr 22, 2009
    Grey line across the middle of each copy
    Sergeant:
  • 284 Answers
Try doing a internal printout. press function -6-4-start. and if that looks good then it might be your scaning glass, if not you need to change your toner
Posted on Nov 24, 2008
    Genius:
  • 1,605 Answers
Yes change a toner and clean the glass area under nearth the toner.
Posted on Oct 24, 2008
Keeps printing pg 1... sender's machine says it isn't going thru
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to reboot
Jan 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax machine sending black pages
Make a copy. How do the copies look? You may have a bad LED assembly.
Also press Function 64 set, Are the prints black?
Nov 06, 2008 | Panasonic PANAFAX UF-6000 Fax
Paper has dark marks down middle
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Oct 23, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Panafax 550 leaving heavey black lines on pages
Clean the optical area with a soft cotton piece of cloth and window cleaner. How does the cartrige looks like, if you see toner on the drum you may consider replacing the cleaning bladeand the drum if necessary. The cartridge was refilled?
Oct 14, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
PANAFAX UF880 - no power
This issue is under the wrong topic area. I have started another issue under the proper topic. Please ignore this thread.
Aug 04, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Time and Date
1) select function #7
2) select #1
3) select "set"
4) enter the new date and time (MMDDYYY) (1500 - 3:00 PM)
5) select "set" and stop
Apr 15, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax Logo
198 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
