Question about Compaq iPAQ H3630 Pocket PC
My iPAQ turns off when i pull the charger.
Hi! I'm having a problem i've searched, and although i've found similar problems, none was a exact match. My iPAQ seems to work properly, and the orange light blinks like if it's charging, but even with external battery, as soon as i pull the charger it goes off, is this battery problems, or another kind? please help! Tanx!
The charging circuit is probably u/s a common fault with 2210,had mine replaced under gurantee
Posted on Apr 27, 2007
Try a hard re set
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using...
I had same problem with my Sattelite L300. Motherboard has a defect in one Proadlizer film capacitor exactly on the back of CPU, the original ref. is nec-tokin 0E907 (900uF/2.5V) or similar code. I've replaced it by 4 tantalum capacitores of 470uF/2.5V each and 2 capacitores of 220uF/2.5V, all in paralell mode in same old place of nec-tokin component.
Vote for me... :)3_10_2012_6_45_55_pm.jpg
Apr 12, 2011 | Toshiba SatteliteĀ® A105-S2051 PC Notebook
After switching on the projector displays message 'searching for source' then 'no source found'. Computer is connected to Optima EP7155 using vga cable.
1 check VGA cable for damage (try other cable)
2 check connections
3 make sure you have resolution on PC is faling in projectors resolution range
4 if it is laptop, make sure you have it in external monitor mode (usually Fn + F8 keys)
Mar 01, 2011 | Optoma EP7155 Projector
I need a charger for my hp ipaq but i don't know what series
In general, there's three types of charger you might need. Really ancient iPAqs used a round DC jack type charger, then there was a long time where all iPaqs used the same flat 22-pin connector. More recently, HP has moved to the same mini-USB plug used for a lot of mobile devices.
If you're really stuck, try http://www.ipaqrepair.co.uk/store.php?cat_id=25 and match your iPaq to the pictures.
Jan 12, 2010 | HP iPAQ 612C Smartphone
Ipaq 3850
Here's an eBay auction for a the ipaq, cradle and cover, no bids yet.
There are also a number of chargers available. A Google search also returns several vendors for ipaqs and accessories.
Apr 02, 2009 | Compaq iPAQ H3850 Pocket PC
HP iPAQ rx 5915 will not turn on
seems like you have a problem with your charger.happened to me too.did you try charging the ipaq via the usb cable on your computer?
Jan 22, 2009 | HP iPAQ rx5915
Only works while plugged in
i would say def. its the battery thats dead!
Did a quick search for batteries and found a lot and costs about 10-30$ for a battery
and some include a charger as well.
Worth spending if you gonna use it daily!
Dec 27, 2008 | HP iPAQ H3835 Pocket PC
New hp ipaq enterprise 210 won't start from mains
worst HP site on earth, but welcome!
never post email on any forum that be bad bad news.
why do that, erase that, want 1billion SPAM in one day
wow. that is scary, no?
like here
http://support.hp.com/us-en/product/HP-iPAQ-210-Enterprise-Handheld-series/3544499/model/3544500/
or here
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=3544500
your A/C walls mains,power pack is no good
it runs on battery
is proof.
in most cased. only real tests, tell real truth'
but you have no meters, or know how to dismantile
this device.
Mar 01, 2017 | HP iPAQ HX2490 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
Turning off ipaq
I noticed the same thing on my IPAQ, and found that if I push the button (somewhat quicly) TWICE that it turns it off completely. Also, you might want to check to see if you have it set up so that it will turn on when you push ANY button (it may not make a difference but I found that when I was putting mine back into the wallet holder I use, I'd inadvertently hit a button and it would turn back on!) :>
Sep 14, 2005 | HP iPAQ HX2755 Pocket PC
Compaq iPAQ H3630 Pocket PC Logo
133 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
