Question about Saws
I need to reassemble the trigger on my Boschmann Miter saw. Any diagrams available?
Trigger not working, once i connect power to the saw it starts without me pressing the trigger. I took off the cover round the handle to reveal the slider and spring but now i can seem to work out how to reassemble it.
5 Suggested Answers
  • 199 Answers
SOURCE: replacement part not available
I had the same problem and the parts are available but they are expensive. There isa spring loaded double contact switch. Take it apart. You will have to drill the rivets out and reassemble with some sheet metal screws or machine screws and nuts. Careful when you open because the parts may fall out. You will want to know how it is built. Usually only one contact goes bad so hard wire the side without continuity(solder together & heat shrink or black tape). The rest is just good mechanical inclination. You will figure it out.
Posted on Jul 05, 2009
airnailer
  • 109 Answers
SOURCE: bench pro
replace the inner switch.
Posted on Dec 02, 2009
  • 478 Answers
SOURCE: I have a Hitachi C10FSH compound miter saw. I love
no the break needs ajusting
Posted on Dec 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: the saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Posted on Jan 14, 2010
My saw won't run when I press the switch trigger.
First, check the outlet it's plugged into.
Power cords can go open, try holding the trigger (careful), and bend the power cord near the plug, and near the saw.
Trigger switches can go out.
saw motors can go out.
Jun 08, 2015 | Ryobi 10 In Miter Saw With Laser
My hitachi miter saw started to buzz when plugged in. It's seems to work normal when trigger is pulled but starts to smoke when I release the trigger. Bushing poor good. I have no idea what is wrong?
have it investigated by an appliance repair shop
the system is this
plug in --no noise
pull trigger -- blade spins and makes running noise
release trigger and blade stops -- no noise
anything else indicates a serious problem with the unit especially if it is smoking.
May 20, 2015 | Saws
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
Why miter saw dws780 wont turn on
Have you checked the manual. My Dewalt Dws780 was not turning on, then I checked the manual and able to start it. There was some sort of plug issue with my saw but thankfully it sorted out quickly. I got this saw from this video recommendation.
Aug 13, 2014 | Dewalt DWS780 12-in Double Bevel Sliding...
I have a dewalt DW712 8.5" slide saw. My trigger came apart, i need to know how to reassemble the trigger? " where do the springs go" for instance?
The spring is positioned so as to provide a constant pressure on the switch so when it is depressed the switch will close the electrical circuit. If you go to the DeWalt home page and query the model for a repair diagram will also assist. You will need some back ground in assembly and mechanical drafting.
May 20, 2014 | Saws
Mitre saw running, but not switched on?
there should be no power going anywhere until you pull on the trigger. With that in mind I would be looking at the switch for the fault
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
My 10 inch miter saw will not turn off when I release the trigger.
Get some Paslode tool cleaner and spray it all around the crevices of the trigger using the tube(straw) provided,while pulling the trigger back and releasing several times. You have debris in the mechanism.
Jun 05, 2011 | Ryobi 10 In Miter Saw With Laser
Need wiring diagram to check continuity on trigger switchfor makita 2400b
If you cannot find wireing diagram,just have the saw unplugged and take one of the wires connected to the trigger off. Then by useing an ohm meter you can check for continuity.
Feb 21, 2010 | Makita 10" Miter Saw LS1030N
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Cannot rotate the Dewalt 708 mod 3 saw horizontally
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
Feb 09, 2009 | Cross Dewalt& 12" Double-Bevel Compound...
Saws Logo
44 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
