Question about JVC AV-32FA44 32" TV
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
I turned on the tv, all was fine for about a minute. Then the tv made a very loud pop, and the tv screen went black, then out, no sound. The timer light is green, but the tv power button will not turn the tv on. TV's tag says it was manufactured in 2003--so this is only five plus years ago.
Is it worth the cost of the repair (whatever it is), or should I just get a new tv?
Thank you!!
Its the power cap mine did the same thing about 11 months into daily use
Posted on Mar 17, 2009
Turned on my JVC AV-31FA44 32
Check its power regulator section and Line Output Transformer. The work is a skilled one, and only an expereinced service technician can go for ward. You must have its repair book with you too.
Apr 11, 2012 | JVC AV-32FA44 32" TV
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
The TV turned off, and the ON Timer is blinking
Ur power inverter board is dead.U need a new one.
Sep 24, 2009 | JVC AV-32FA44 32" TV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC av-32fa44 The menu (picture, sound settings, etc)will appear and scroll through all the settings continuosly, and remote cannot close the menu. Power off tv for a minute will clear the problem, but...
Sounds like one of the front panel buttons is jammed. press each one and see if any fail to "rebound" or feel different from the rest. You can usually work the button in a 'circular motion" to release it. If the buttons seem normal , it's possible that the switch inside the TV has collapsed
Mar 10, 2009 | JVC AV-32D305 32" TV
TV made a loud pop
hi,
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
Jul 11, 2008 | JVC AV-32FA44 32" TV
No picture, No sound
Hi there!
If the set is dead after the popping sound, then it has probably blown a component due to high voltage. Everything inside a tv starts with the power supply. Nothing will work unless the power supply is 100%. I don't know what your rates for repairs are in general, but the price sounds good. The final decision is yours to repair or replace. Good Luck, JUS004
Jan 24, 2008 | JVC AV-32FA44 32" TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
JVC AV-32FA44 32" - No Picture, but sound OK
You could have a power supply problem as parts do go bad. Why your set faile is a mystery.. Of course if your not a technician, a TV set is NO place to be experimenting with. It only about a year old you say But get the papers on this set if you can find them and make sure as there is a 12 month warranty on this model. You should contact JVC At 1-800-252-5722 or online at http://www.jvc.com/support/. Good Luck
Aug 07, 2006 | JVC AV-32FA44 32" TV
JVC AV-32FA44 32" TV Logo
297 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
