Davis,
You can restore the system to factory conditions by following the information below.
Dell Factory Image Restore
The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu.
Start the computer and TAP the F8 key. Once the options appear on the screen you can choose Repair Your Computer and follow the prompts to restore the computer to factory conditions. CAUTION:
This utility formats the operating system hard drive partition prior to restoring the factory image. This means data on that partition is deleted and cannot be recovered.
If the customer creates a second partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
You'll need restore disks or if there is a restore partition on the hard drive then you can restore it from there. It will be less problematic to get some anti virus software to rid the computer of a virus.
The docs, including the service manual, for the Dell Vostro 238 are at this web page. If you're looking for an actual circuit board schematic, you're probably out of luck. If you need the board layout for jumpers and so forth, the service manual page 28 is for you.
Resetting
a Dell Vostro to the factory settings allows the user to restore the
Dell Vostro to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Vostro laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Vostro reset process...
This
process will erase all your previous changes that have been made to the
Dell Vostro laptop and reset the configuration settings to factory
setting.
If you wish to FORMAT your hard drive so you can re install the OS.
Put your Windows disc into the CD/DVD drive, boot the computer and press F2 (if that does not work try CTRL+ALT and enter) to enter the bios. Change the boot order to boot from the CD drive first.
Follow the onscreen instructions to Install the OS, you should get the option to delete the existing partitions and then to FORMAT.
Resetting
Step 1:
This
setting.
