Question about Electrical Supplies
How do i change the spark plug in my 7800 watt troy built generator?
How do i change the spark plug?
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 4088 Answers
SOURCE: I have a Troy Bilt 7800 portable generator. It produces no power.
Make sure the generator/alternator is being driven by the engine. Couplers fail often enough to consider the possibility.
Posted on Sep 14, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
Troy built weedwacker wont start
Try draining the fuel and re filling with fresh, if no better, does it have a spark at the plug? does the plug get wet with fuel? if not try replacing the fuel filter in the fuel tank.
Feb 16, 2012 | Garden
TROT-BILT 7800 WATT GEN. ONLY RUNS ON FULL CHOKE
Hello, your main jet is plugged with varnish or corroded with water. You need to remove the float bowl and see which it is and clean it. That will fix your problem.
Feb 06, 2011 | Briggs & Stratton Briggs Stratton 6200...
Sep 14, 2009 | Electrical Supplies
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Jun 20, 2009 | Electrical Supplies
Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Jun 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Mar 29, 2009 | Electrical Supplies
No spark?
I answered a question very similar to this one here, when you do get it to start you may find that you have to flash the field on it to get it to make electricity, you can ask me how if you like.
Carl
Nov 20, 2008 | Electrical Supplies
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
