Question about Coleman Grilling
Connect propane to stove for popup
The piece that connects the propane tank to the hose for stove
  • Coleman Master
  • 2,461 Answers
Try canadian tire they sell these hoses take it with you as a guide
Posted on Feb 18, 2012
SOURCE: propane hose has a hole
Many "old-fashioned" hardware stoves have a ribbed tube that fits inside the hose and a pair of clamps for the outside. Cut the hose where the leak is, put a clamp on each side of the cut, slide the ribbed tube into one side of the cut, push on the other side of the tube, tighten the clamps and you are done. Except for the shopping trip, it should take less than five minutes for the fix and the only tolls you will need ar a knide (or limb pruner) and a screwdriver.
Posted on Aug 25, 2007
woobie dog
  • 1273 Answers
SOURCE: Char-Broil QuickSet. cheap old school. i
Hi, Kelly,
I converted one a few years back, and got most all of the parts I needed from the local gas company. The few parts they didn't have, I got from Lowe's. I got something I wasn't expecting in the bargain - expert advice at the gas company. They just loved talking about converting to NatGas and couldn't have been more helpful. Try your local company. I bet they have the same type of folks there. By the bye, some gas co's will make the conversion to NatGas for you for free. Check it out!
Regards! --W/D--
Posted on Jul 12, 2009
bulldogchief
  • 388 Answers
SOURCE: Gas not getting to stove to ingnite
It sounds like you may be "vapor locking" the grill...after you are done cooking on the grill, how do you shut it off? Do you close the tank valve first then close the burner valves or do you turn off the burner valves then shut the gas off at the tank? If you turn the burners off before turning the gas off, you are creating a "vapor-lock" where air gets trapped in the line and you get the sputtering you are talking about.
Try this first, turn the gas on, then light the grill...once it is lit, turn off the gas and wait for the flame to fully extinguish then turn the burners off. Now try to light it again...if it is still sputtering, repeat the procedure above to purge the air out of the line.
If that procedure does not fix your issue after three tries, go get a new line and regulator and install then do that same procedure again. This should fix your issue once and for all.
If you experience any trouble with this, let me know here. Good Luck!
Posted on Oct 30, 2009
  • 332 Answers
SOURCE: propane tank connections keep freezing
You have a leak at that connection, LP gas must be present to freeze. Please find the fix before you use the BBQ
Check the small "O" ring on the end of your POL connection
Posted on Mar 07, 2010
  • 512 Answers
SOURCE: Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
Posted on Apr 07, 2010
I have a Kenmore 14116329 propane grill. The propane tank is full but when I turn on the burners very little gas comes out resulting in a VERY low flame. Is it the regulator or???
It is most likely the saftey check valve in the tank. The procedure is to:
  • Close tank valve.
  • Disconnect hose connection from grill to tank.
  • Wait
  • Reconnect hose connection from grill to tank
  • "Slowly" open valve on tank to release gas back into grill
Through on some steaks
If still a problem replace tank.
The check valve that can cause your problem drastically reduces propane flow in case of an accident and the lines are ruptured
Hope this helps?
Jul 03, 2017 | Kenmore Grilling
Smell Propane
I have the same issue when the tank starts to get low and nearing the time too refill. Just thought I would share that in case that is the issue. I also redid all my connections the first time it happened.
Apr 13, 2014 | Frigidaire FFGF3023LM 30" Freestanding Gas...
1998 discovery motorhome turned on propane at tank no gas at stove.is there a another shut off valve
It can take a while for the propane to get to the stove. ( 20 seconds maybe ) All the air has to bleed out of the line first. Also , if you have 2 tanks , there could be a selector switch on the regulator where the 2 tank hoses come in , that has to be selected to the tank that you have opened the valve on.
Oct 03, 2013 | Cars & Trucks
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
I connect the propane valve to the stove and it doesn't work, i just bought a new propane and still it doesn't work, my grandfater didn't use it for almos 4 years. what could happened?
Here's an easy solution. Turn the Tank Valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect connect the hose to the tank and turn the Tank Valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the grill first. Once it lights, turn it to it's highest setting and light the remaining burners the same way. Once all are lit, does the flame height look as it should? Is so, you solved the problem. If not, then you need to replace the grill hose/regulator assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
If what I suggested solved the problem, remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you solve the problem.
Apr 09, 2011 | Camp Chef TB-90LWG (NG) Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Check light fading in and out
you may need to have te pressure check to 14"waterculum you may have to much pressur or not enouht pressure have it check by tech
Feb 14, 2009 | Dometic RM2652 Refrigerator
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Grilling Logo
87 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
