Question about Drills
Oil type for te 7-a
It was previously slow drilling and heavy smoke coming from it after short drilling time
  • 2,176 Answers
You probably have an electrical issue that needs to be fixed. If you want to try and repair this yourself I suggest calling Hilti direct at 1-800-879-8000 for a breakdown and location of a service center for parts availability.
Posted on Mar 01, 2012
No oil in engine
8000 over is not good. You lose some oil to what is called "blow by". This is when oil pushed by the rings around the pistons. This is a slow process but over time you could lose a bit and not notice any smoke. Also over time oil breaks down when not changed often causing a lot of it to stick to enternal parts of the engine which could be why you didnt get a light. Just some thoughts, sorry about your troubles
Jan 08, 2013 | Cars & Trucks
Hi. I was drilling a few holes in concrete with my TE 56 HILTI and the drill bit become jammed. it began to smoke so i put a new set of brushes in it and still the same spins slow and smokes, any...
It sound like is has overheated or a bearing has seized. Take it to hilti. www.hilti.co.uk for nearest dealer. They will collect for a price.
Dec 11, 2012 | Drills
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Overfilled engine oil on a 2003 porsche 911 turbo.now smoke comes out of exhaust--HEAVY Smoke.I drained engine oil again(along with the turbo)put in 9.25 qts of oil,still having heavy smoke.
The oil was overfilled this could cause a large amount of oil to enter the exaust and possibly the intake depending on crank case ventilation conditions. If you are positive engine oil levels are adjusted perfectly(warm engine check level running for dry sump oil level ect.). Time is needed to burn off oil residue in exhaust system and intake. Warm up engine low rpm no load, drive vehicle slow with little boost over 5 mins slowly raise rpms for another 5 mins keep driving smoke will burn off while making other drivers mad. sorry just smile and wave.
The engine oil on this vehicle should only be changed by an experinced tech.
Sep 30, 2010 | 2000 Porsche 911 Carrera
Amount of oil
Around 50cc's if it is still wet. 70cc if dry inside
Aug 02, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Using drill battery started getting extremly hot/ removed and it continued to get hot and started smoking. Put second battery in drill and same thing happened again. Whats Up?
the drill apparently has created a short in the battery contacts. Look at the contacts and then the switch contacts, there might be a wire going to ground against the motor or the switch has shorted creating this problem.
Dec 22, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Oct 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Aug 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
67 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
