Question about Sharp Audio Players & Recorders
Cd player does not eject
Cd player portion of the boombox does not eject the cd tray which can hold up to three compact discs. Took top off and noticed the motor which turns the tray would not turn on.
5 Suggested Answers
fairlane
  • 50 Answers
SOURCE: Boombox CD player
Hi Could be bad spin motor, but the first thing to try is load the cd and put your ear to the unit and listen for a ticking sound...if there is, then the laser is trying to focus. If not ticking, there is likely a serious problem, and the whole unit should be replaced. If you hear the lense bouncing up and down, then it is likely a dirty lense or bad laser. To clean it, use a cotton swab and wet the end with at least 70% USP rubbing alchohol(99% better). Touch the swab to the lense and a drop should form on the lense, gently move the drop around to loosen any debris, and then use a dry swab and touch it to the lense to absorb the drop. Try the unit, and if it was dirt on the lense, it should work, if not the boombox should probably be replaced. Good Luck!
Posted on Sep 27, 2007
Kaoeria
  • 36 Answers
SOURCE: CD player/boombox
Alot of cd players, theres a tiny tiny pin hole you can fit maybe a sewing needle, or the end of a paper clip into... do it, and ull probably feel a lil resistance while the internal button is pushed...once u hear like u pressed it, the tray should open.
Posted on Dec 28, 2007
odiebugs
  • 949 Answers
SOURCE: We have a CD that somehow is stuck inside the Sony
Tilt it forward, eject the tray, and shake the box and see if it falls out.
Posted on Apr 09, 2009
  • 15 Answers
SOURCE: Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
Posted on Jun 15, 2009
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
I put 2 cd's on top of eachother. now the cd player wont open but it will turn on. when i turn it on it says mechanical error.
You could try gently sliding a thin blade in the top of the tray slot to hold the CDs down whilst, equally gently prising the underside of the tray with a small screwdriver (it may help to press teh open/eject button at the same time).
Feb 25, 2011 | Onkyo DX-C390 6-Disc CD Changer
VUP 0/9 KEEPS FLASHING DURING FIRMWARE UPGRADE NOW ITS MORE THAN ONE HOUR
I had the same problem when I made the mistake of trying to do a firmware upgrade via CD-R instead of the Network option. My player is no longer connected to the internet so I created a CD-R following the directions on Sony's site. The CD-R attempted to do the upgrade, but was stuck at 0/9 and I could hear the disc trying to read. The problem is the disc you created. You need to make another one. On the Mac, I used the Finder to burn the disc per Sony's instructions. That is what failed in the player. My second CD was created with Roxio's Toast Titanium, PC/Mac Data CD-R. If you have Windows, I would suggest using a commercial burning CD program, like EasyCD Creator and burn the two update files to the root level of the CD. Make sure the disc is finalized.
Next, you need to open the player to manually release the tray to eject the CD and swap it with your new disc. Remove the two back screws on each side. This removes the two side trim panels. Remove the two screws holding the top trim panel on each side. Then slide the top trim panel from front to rear to release the panel. If that doesn't work, open the CD cover door with your finger and then gently pull up on the top panel at the front edge to release the clips along the front, across the entire front edge. Then slide the panel back to remove it. Then remove the three screws at the front edge, and two more screws on each side. There is also one screw at the rear top edge. Remove the top panel. Then get a long paper clip. Looking at the front of the player, the manual eject hole is on the right side of the optical drive. Above the hole is an E engraved above the hole. Insert the paper clip straight into the hole and you should be able to push the release mechanism causing the tray to open. You might have to fish around a little. Slide the tray open and replace the disc with the newly burned disc (or obtain a disc from Sony for free through their website). Close the tray. You can leave the player open. Plug in the power cord and the upgrade will continue where it left off. It may take a minute or two, but you will see the VUP advance to 9/9, then finish. The tray will open and you can remove the disc. Close the tray and the player may reboot again. Once you see the No Disc message, turn off the player and pull the power cord. Reassemble in reverse order and reconnect your player to your TV and it will have the new firmware.
Oct 04, 2010 | Sony BDP-S550 Blu-Ray Player
Doesn't read the cd. says
If any cd player does not play, three things, it either the wrong format, dirty cd or faulty cd player. If your cd player play others cd, it mean others are the wrong format. for example older cd player is not compatible to play some of the cd formatted from the computer. if the cd player does not play anything that mean the cd player is faulty.
Aug 27, 2009 | Sony Audio Players & Recorders
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
20 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
