Question about Leica Digilux 1 Digital Camera
WHAT DOES LEICA DIGILUX 1 GREEN FLASHING LIGHT
4 Suggested Answers
ssemul
  • 202 Answers
SOURCE: I own a Leica DIGILUX
there is problem with key switches may be there is some due or some water drop goes in side. check by opening your camera if you find then clean it.see what hapen if still problem need to replace key switches.
Posted on Oct 18, 2010
Testimonial: "Amazingly Prompt helpful particularly regarding Leica cameras as there are not many authorised service centres in India. Thanks. SK Pillai"
  • 102366 Answers
SOURCE: best make and largest size of sd card for the leica digilux 2
The Digilux 2 will work with any SD card, but bear in mind that SD cards max out at 2GB. Larger cards are actually SDHC cards and will not work in the Digilux 2.
Posted on Jan 31, 2011
SOURCE: When I turn on my
Odd this has been here five months w/o a response. Apparently you describe a "burned out CCD", the famous "sensor problem", which is frequently mentioned whenever the Digilux 2 is being discussed. It's too bad because I think otherwise it is a wonderful camera. Contact Leica in whatever country you live and see what the current policy is re: repair, and whether the company will stand behind their product. There appears to have been positive response. Good luck.
Posted on Apr 02, 2011
When the green light flashes quickly while charging what problem can I consider looking into? Would it be that I need a new battery or a battery charger?
Hi Carmen- I am experiencing the same issue with my 2 DIgilux 1 camera, after a long time of not using them. In fact, One of them had a broken lens motor for the longest time and that seems to have fixed itself. I have 2 new batteries on order to see if thtat resolves.
Dec 23, 2013 | Leica Digilux 1 Digital Camera
Hello, I have recently bought a Leica Digilux 1 but I can't use it since it always marks "Memory Card Error". I have tried with three different memory cards and that sign keeps on appearing....
First make sure that any pics on the cards are safely downloaded to your computer. To get the cards to work in the Leica, you must format them in the camera. This will erase them and set them for the operating system of the camera.
Aug 17, 2011 | Leica Digilux 1 Digital Camera
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
I need the manual for digital camera leica v-lux 1 in Spanish, as I can find
Hola, de seguro en el manual en alemán encuentra la direccion de Leica para solicitarles un ejemplar en español.
Saludos
Feb 25, 2011 | Leica Digilux 1 Digital Camera
When I turn on my Leica digilux-2, the monitor shows a photo from the SD card, but does not pick up anything else. The viewfinder is black.
Nov 10, 2010 | Leica Digilux 2 Digital Camera
Best make and largest size of sd card for the leica digilux 2
Apr 18, 2010 | Leica Digilux 2 Digital Camera
Green LED won't turn off
Switch the camera off,
take the battery our,
put the battery back in,
switch camera on,
problem solved.
Jan 23, 2008 | Leica Digilux 1 Digital Camera
Digilux 2 problem
No solution- Humidity and moisture is death to Digital Cameras
Sep 28, 2007 | Leica Digilux 2 Digital Camera
No picture thru viewfinder or monitor
Okay, I have found the solution (along with Megant, it appears.) It is definitely a dead sensor issue. I contacted Leica via email (cs@leica-camera.com) and received a response from JoAnn Scott, a Leica customer service manager (joann.scott@leicacamerausa.com) stating that the sensor issue is a common one and is covered under an extended warranty. I shipped my Digilux 2 to this address:
Leica Camera Inc. / Customer Service Manager
Re: Dead Sensor Repair
1 Pearl Court, Unit A / Allendale, NJ 07401 / USA
and within 2 weeks received a repair ticket from Leica, identifying the issue and indicating a zero balance for the repair. A follow up with JoAnn revealed that the turnaround time on the repair would be 4 to 6 weeks. The most expensive part of this whole deal was the 18 dollars I spent insuring the camera when I sent it back via the USPS.
Hope this helps.
Feb 02, 2007 | Leica Digilux 2 Digital Camera
Leica Digilux 1 Digital Camera Logo
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
xalint1
xalint1
Are you a Leica Camera Expert? Answer questions, earn points and help others
