Question about Kenmore Vacuums
Kenmore vacuum model 116.23512301 power switch
Power switch for Kenmore model 116.23512301 serial #: D40912894
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 1214 Answers
SOURCE: open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Posted on Jan 15, 2009
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
renevacdoc
  • 84 Answers
SOURCE: Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Posted on Nov 10, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same issue. The holder for the micro switch is very weak and will open up and allow the switch to come loose, and in my case the was not enough slack in the wire. I unplugged the unit, pressed the pedal and laid it down. Open up the bagger door and remove the bag and filter. Remove 4 screws in the bagger compartment, remove 2 screws by InteliClean indicator lights, remove 4 screws on the outside close to the light. You will be removing the blue upper case. Remove the upper case and look on the right where the lower agitator section pivots. There you will see a micro switch. I ended up lifting and tilting the lower pivot section to the side, repositioning the switch in the holder, and then wedging a full glue stick (not melting but wedging) between the white plastic housing and the switch holder. This added the strength needed to the switch housing to hold it in place. Put it all back together, install the filter and bag. This fixed mine. Good Luck.
Posted on Feb 27, 2010
Sears kenmore vacuum 116.23401211C hardly used, suddenly no power at all. Cannot find manual, appears to be no fuse or reset on this model? Thx!
There is no fuse there is no reset either. If it doesn't run most likely the vacuum cleaner suction motor is defective or the power switch.
Feb 16, 2017 | Kenmore Vacuums
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
I have a computerized Kenmore 150 the model # is 385. 19150090 and the serial # is 31001565 the problem is every time you turn it on it says overload and it will not do anything any sugestions? or what...
This happened to me too. I was using the wrong bobbins and when I would try to sew, the bobbin would slide up and down. I switched to a Kenmore bobbin and my machine hasn't given me any more trouble.
Jan 25, 2011 | Kenmore Vacuums
I need a model number for the kenmore durapower vacuum. Don't have the manual can't find on vacuum
Hi There,
The model number will either be located on the bottom or the back of the machine on a sticker that also contains the serial number. All vacuums have to have this sticker, and serial number information on the machine somewhere. On uprights it's usually on the back of the machine towards the bottom, or on the very bottom of the floor nozzle part. On canister vacuums the model number will either be found on the bottom of the canister, or on the bottom of the power nozzle.
Hope this helped!
Chris
Apr 20, 2010 | Kenmore Vacuums
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
Kenmore vacuum model 25614 power mate will not reset
What you see from the outside is usually a pop up button which sits on top of the actual internal switch remove the lid of the power mate as though you are cleaning the brush roll or changing the belt. Then test the reset internally. Post back to advise .
Sep 19, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore vaccum cleaner
Switch number is 4369051 . You can go to sears.com, click on the parts link, put in the part number and you can order it thru them. Or put in you model number, click on dust compartment and a parts list and a picutre diagram will come up. You can order there also.
Mar 20, 2008 | Vacuums
Vacuums Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
