Question about Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator
10 hp b&s engine will not run with choke open
    Problem Solver:
  • 9 Answers
Sounds like your carb needs rebuilt .This condition is caused by blockage of ports and jets in the carb .Running a fuel stabilizer will help prevent this .
Posted on Feb 18, 2012
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Engine only runs with choke on
turn off fule first take the bowl off bottom of card by removeing the 10 mm stud .use an air line to blow out carb where the stud came out of.now turn on fule and make sure it runs trough the float needle if it does turn off again .replace bowl turn on fuel and start up.
Oct 19, 2012 | 5.5 HP GX160 Engine
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a firefighting pump with a honda engine it
above the startercord there are 2 handles. top one is grey is choke , bottom is black, is fuel tap. first open fuel tap put on choke, start, after 5 or 10 seconds put choke off. if its not starting on choke, gets no fuel. under fueltap is chamber with 10 mil bolt. open and clean. also drain or take off floaterchamber of carb. this is the round cup under the carb. good luck.
Feb 12, 2010 | Honda 8 HP Engine
83 s-10 2.8 engine needs choked to idle. Open choke
hi if your backfiring your timing is a little out also increase you idle speed on your carb by ajusting your throttle screw hope this helps if you find this useful please rate it thanks
Nov 20, 2009 | 1983 Chevrolet S-10
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Describe your Briggs & Stratton
you need to rebuild carb and check groverner spring
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Briggs & Stratton Briggs  Stratton 6200 Watt Portable Generator Logo
341 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
