Question about Fujitsu P50XHA10 50 in. Plasma Television
Fujitsu P50XHA10E no picture
I have acquired a Fujitsu P50XHA10E that has an intermittent problem.  Sometimes when I turn it on there is no picture.  After cycling the power the screen will energize.   When it is having the issue the screen is completely black  and will not even display the menu or input display.   Also, It will shut itself down and then the red status  light blinks (short, long, short). Does anyone know which  board I should replace? Thanks for your help.
  • 534 Answers
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Posted on Jun 05, 2009
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Feb 25, 2016 | Samsung Televison & Video
Onkyo tx-sr674 loss of picture and sound
Change the HMDI cable, might fix the problem, intermittents of this type are very difficult to trouble shoot.
Mar 12, 2012 | Onkyo TX-SR674 Receiver
When tv is turned on picture is distorted.then upper 2" of picture is good.After 20 minutes or so picture will come on but will freze intermittently
Tv it is the causes and the problems of the board call tv Tuner signal board it is dying.The tv Tuner signal board it is the board,where the incomming signal cable plug into.U have some mechanical skills?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 13, 2011 | Vizio SV370XVT TV
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Fujitsu P50XHA10E
Maybe inverter board is getting ready to go out. Only suggestion is to reset tv by unplugging from power source. Sometimes this will clear up strange problems like that. Best I can do for now.
Jun 02, 2008 | Fujitsu P50XHA10 50 in. Plasma Television
Acquiring satellittes function is not working
This will sound absurd, but I have had 100% success with the following "fix" for 3 months now: drop the unit on a table from a height of 10 to 12 inches and then power up. It acquires every time! I have reloaded firmware, reset, everything and this problem persists. I do not get satellites about 9 out of 10 times I power up. Then I drop it and try again and I always get them. I think it's a cracked circuit board? I waited 3 months before posting this to rule out coincidence. If this method is a coincidence, then it is an amazing one that repeats over and over again!
Apr 25, 2008 | Garmin Edge 305 GPS Receiver
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Intermittent convergence (IC?) problem
Can be bad solder connections on IC pins, but intermittent
conditions can damage IC's, so we usually replace because
the labor to get the board out is the same ..........Three to five
years on a pair of convergence IC's is normal.........T.
Nov 04, 2007 | Sony KP-51WS510 51" Rear Projection...
Fujitsu P50XHA10 50 in. Plasma Television Logo
457 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
