My Amana Air Command 80 SSE IIQ Gas Furnace started up for a few seconds the shut down with no indicator light. I went up and switched disconnect off and on, then checked all connections and fuse on circuit board, all good. Closed up unit and it started running. Good for a day or so then repeat. I replaced circuit board about 6 months ago.
    Sergeant:
  • 338 Answers
Have you cleaned your flame sensor? Take a piece of emery cloth or a piece of light sand paper and sand it a little. It is located in the burner section and it is usually to the left side of the unit and it looks like a L. Hope this helps.
Posted on Feb 14, 2012
huuum
  • 750 Answers
SOURCE: Amana Air Command 80, 20
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Electronic ignition.
Furnace does not start.
Good power to furnace.
Thermostat properly set.
Where do I start looking?
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Posted on Oct 13, 2008
  • 57 Answers
SOURCE: I have a Amana air
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Posted on Oct 18, 2008
  • 85 Answers
SOURCE: my amana 80 sse furnace
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Posted on Dec 11, 2008
tborn6
  • 700 Answers
SOURCE: furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
Posted on Dec 23, 2008
james3751
  • 614 Answers
SOURCE: Amana Air Command 80 blower won't come on
Sounds like fan relay or fan motor possibly capacitor. Call a service tech for free estimate on repair. that wasy you know upfront your cost.Rus
Posted on Jun 25, 2009
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
Amana Gas furnace, Air Command 80 SV. Does not ignite. The blower turns on, then gas valve opens. I can hear a mechanical switch close, which is probably the igniter control. But no spark, no flame. ...
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Dec 02, 2008 | Amana Heating & Cooling
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
Huuum
Thank You,
Oct 12, 2008 | Amana Heating & Cooling
Furnace manual
May 26, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
628 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
