Question about Dell Latitude D430 Notebook
Monitor turns black
I have a D430 and recently, when the power brick is plugged into the laptop, and when powered on, the display shows in second and turns black. But when off of power brick, the monitor display works. Any help will be appreciated. Thanks!
  • 93 Answers
As you had stated that the monitor is working if the power brick is off.The back light shutdown might be a cause of static from your power brick, or other thing is it might be your setting for back light level or power scheme.Some configuration needs to open BIOS settings.To check if the power brick is the cause of problem is good to have a known good one or try to monitor if it is charging or not by monitoring the battery indicator if the power brick is off.
Posted on May 26, 2012
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
Geekman
  • 32281 Answers
SOURCE: flashing on and off
Is the monitor a LCD monitor and does it uses a power adapter?
If this is the case then it could be the power adapter that is faulty or if it is underpowered and the thermal overload cuts in then it switches off and when it cools it switches back on again.
Check the monitors power specs and the adapter should match the power requirements of the monitor or greater (ie. the voltage should be the same but the current rating should be the same or greater).
Posted on Feb 10, 2009
tleeski
  • 29 Answers
SOURCE: D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Posted on Feb 12, 2009
  • 59 Answers
SOURCE: the laptop screen is almost blank/black. an
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Posted on Jan 20, 2010
  • 28 Answers
SOURCE: when i try to connect
Have you tried the following:
Hold the FN key down and hit the CRT/LCD button?
Posted on Mar 14, 2011
My computer will turn on , but nothing will show up in the display.
power if off and when you power it back on, start hitting the F8 button every couple of seconds. If you can get it booted into Safe Mode, try restoring it back to a date that it was working. Also look for a blue VGA port. If there is one, plug in another monitor with a VGA cable to see if it will display.
May 18, 2015 | Compaq Evo N800c Notebook
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
Mar 05, 2014 | HP 1502 LCD Monitor
Toshiba laptop pas409e-d screen is black
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Causes a Computer Monitor to Go Blank b> While a blank screen may be caused by a general power outage, more often it's a problem with the screen itself. It could be a loose video or power cable going to the monitor. If that's the case, you can get the screen working again and be back in business in a few minutes. b> Power Problems All the power might be off due to a bad outlet, switch, fuse, or circuit breaker. If you hear no sound coming from the computer and its power light is off, check the power connection and breaker or fuse. Video Cable Many times the cause of monitor blackouts is a loose video cable connection. This might happen if you move the monitor or the cable. The video cable runs from the back of the computer to the monitor. It has a multi-pin connector on each end and both of them screw down securely. If the screws aren't tight, either connector could become loose. If that happens, the video signal could stop suddenly and make the picture go blank. Check both ends of the connector to make sure they're firmly seated and the screws are tight. The cable itself might be bad.This is unlikely, but possible. b> Display Power The monitor must have power. If the power light isn't lit on the monitor, it may have been turned off or become unplugged. Press the power button to make sure it wasn't accidentally turned off. Make sure the monitor is plugged in. If it's connected to a power strip, check that the power strip is on. If that checks out, unplug the monitor and try a different outlet. Power strip sockets can sometimes fail. Flat-screen monitors may have a power-brick-style adapter. It, too, has connectors. Follow the power cable from the monitor's power plug back to the monitor. About halfway up you'll find a thick rectangular plastic brick. The power goes into a modular-style equipment socket. This can become loose. Follow the wire the rest of the way to the monitor. It connects to the back of the screen with a small round plug. Check that it's firmly plugged in. If everything's plugged in right and the power light on the monitor's still off, the power brick might be bad. b> Video Card Some computers have a separate video card inside. It may come loose and cause a blank screen. If this is the case, open the computer and inspect the video card. Sometimes removing and reseating the card will fix the problem. If it has to be replaced, most video cards are not expensive.
b>
Feb 15, 2013 | Computers & Internet
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
My 18 month toshiba satellite lap top battery is not taking a charge.
I had a similar problem with a Toshiba laptop. Problem was an issue with the bios being out of date. Go to the Toshiba website, download the bios for your model and install per Toshiba's instruction. That should fix the problem.
Dec 06, 2011 | Toshiba Computers & Internet
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
My Compaq Presario F732NR Laptop w/Vista won't Boot.
You have done an excellent job of diagnosing a MotherBoard fault. This is undoubtably the problem. Have you removed all/any cards attached too, like say the WiFi?
Feb 08, 2010 | Computers & Internet
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
Jan 19, 2010 | Dell Latitude D430 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Dell Latitude D430 Notebook Logo
66 people viewed this question
Alun Cox
