Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN problem with faded black images/text only
I've replaced the black cartridge and it did not solve a problem of faded image and printing/copying in black ONLY. if I use any other colors, the same images/text are fine. Only black seems to be the problem. I read somewhere that sometimes the black gets clogged in the imaging unit. Something about cutters getting clogged, I think? Does anyone know how to fix this. Can the image unit be taken apart and cleaned. It's obviously working for all the other colors and it's expensive to buy an imaging unit.
  • John Howard Feb 15, 2012
    Hi and thanks for the quick response,
    I have the manual and have done everything recommended by Samsung as to cleaning out the machine. nothing corrects the issue.
    As suggested by Michael, I did find an option to set the printer to a darker print by default. All that did was to almost turn the areas that were fine to almost a bold print. It had only a slight affect on the areas that are faded.
    To try and paints a picture of what the print looks like, imagine if you printed a full line of text in black, then another in red, then green, then yellow. Then you filled up the page with these alternatinf lines of tcolored text.
    The print on the red, green, and yellow lines are all crisp and perfect.
    The black lines have faded area's accross the line of text. The same faded areas can be found on all the lines with the black text.
    Scholar:
  • 51 Answers
Many of today's printers have a "toner save" option, which makes the black appear lighter, and I'm pretty sure this isn't your problem. However, I wanted to rule-out the obvious first, which is just a setting.
If you're seeing the black lighter in vertical "stripes" or segments in your printing, then it's most likely due to a dirty toner cartridge (but you said you replaced it), or cleaning the LSU inside the unit (as it says in the owners manual).
Just in case you don't have the manual handy, here's an online link to it:http://downloadcenter.samsung.com/content/UM/200611/20061122152910875_CLX-3160_English.pdf
I hope this helps!
Posted on Feb 13, 2012
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Posted on Feb 07, 2008
SOURCE: Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
Posted on Sep 22, 2008
yooperbud
  • 8637 Answers
SOURCE: CLX-3160FN Paper Jam when there
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
myjosh007
  • 530 Answers
SOURCE: My Samsung CLX-3160FN prints with
hi im josh try this: Understanding Potential Problems Printers are mechanical devices with lots of moving parts. And any time you have moving parts, you have something that can break or wear out over time.
So when you click the old print button and nothing happens, what are the likely causes?
First, you might have the wrong printer driver installed in Windows. You might have either simply selected the wrong driver for your printer, or Windows might have mistaken your printer for another model, or the driver selected might be out of date. While we're in this area, it's also possible that various aspects of your printer setup might be incorrect, which can cause some highly unusual problems. You should also check your font setup because fonts themselves can cause perplexing problems if they're not installed correctly.
In addition, any new input or output device you've installed since you installed your main printer could have changed your printer's settings. (It's kind of like the last device installed gets dibs on key system settings.) If you've recently added a scanner or a digital camera or fax software or anything like that and then experienced printer problems, try uninstalling your printer (and all printer drivers) and then reinstalling your printer so that your printer is now the last device installed—and thus controls key system settings.
It's also possible that if you're printing large or graphically complex documents, you might not have enough disk space or memory to print. Make sure that you have plenty of both, because Windows needs all the space it can get to complete the printing operation.
Finally, you could have real printer hardware problems. These problems range from the mundane (you're out of paper, you forgot to turn on the printer, a cable came loose) to the fairly serious (your printer is broken!). Check all your cables and connections and make sure that your printer is actually turned on.
The bottom line is there are a lot of things you need to check if you have printer problems, both hardware- and software-related. So if you have printing problems, hunker down and plow through the problems/solutions section, coming up next.
tip
One of the best ways to track down a printing-related problem is to use the Windows Print Troubleshooter, found in the Help utility.
Problem: Your Printer Prints, but Output Is Smudged or Garbled If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time
  • good luck
Posted on Mar 06, 2009
  • 406 Answers
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
Posted on Jan 07, 2010
I replaced the black toner cartridge but its still printing light
If the print looks something like this with vertical fade bars:
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Jan 19, 2011 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
My pages are printing correctly on the edges but light in the middle on my clx 3160fn. it has a new black ink cartridge
Is it only with one colour ? I had the same problem (only with black) and before buying another unit dismantled the imaging unit to find a build up of toner on the metering plate edge, I cleaned it and now it's fine.
It takes a bit to get to... 3 fixing screws each side plus one for the belt shute and one at the top. Remove the side plates, followed by the image drum (with great care) then each colour toner roller unit (they just slide forward) until the black unit is exposed. Remove the 5 cover fixings and then you can clean the plate edge. kh
Jul 11, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn
This is usually due to the imaging unit going out, but can also be a problem with the main board itself...unfortunately that means rma is really the only option...which is NOT going to be fun fyi as samsung has poor customer service.
Aug 30, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
200 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
