Question about Acer Aspire 5735 Notebook
Always showing the massege consider replace your bettery
T want to solve the issues
    Scholar:
  • 51 Answers
Simply put, replace the battery with a true OEM battery.
I've gotten this on a number of notebooks and their batteries. It's really a matter of whether you use the notebook more on battery power or on AC power, because keeping a battery connected inside a notebook that runs mostly on AC power is a sure way to burn it out sooner.
Essentially, if all you use your notebook for is at home, or where you have access to AC power, then just disconnect the battery and run it on the AC adapter.
If you use it more for portability and rely on the battery, then I'd recommend replacing the battery, and be wary of offshore manufacturers who say they offer OEM replacements at really low cost. It's so true that you get what you pay for, especially with respect to notebook batteries.
When you do get the new battery, I'd suggest getting it fully charged before using it for the first time, and trying to cycle it down (discharging) the battery as low as possible between re-charges to extend the battery life.
As I mentioned previously, continuously keeping most batteries plugged in while operating on an AC adapter tends to limit the useful life and charge duration of these types of batteries, including both NiMH and Lithium (although the latter tends to have less of a "memory effect").
I hope this helps!
Posted on Feb 13, 2012
2 Suggested Answers
  • 2567 Answers
SOURCE: in my hap always showing consider replacing your
Seems that your laptop's battery is defective & needs to be replaced.
To be sure, you can perform the following diagnosis:
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 09, 2010
00426 oem 8992662 00497
You should replace the battery. Once they are bad they only get worse.
Sep 17, 2013 | Computers & Internet
Bettery problem
Replace the battery, it is bad...
Jul 09, 2012 | Dell Vostro 1088
Display massege consider replacing your battery
You may want to do it because it's starting to significantly lose battery life.
Jun 20, 2012 | Dell L VOSTRO A840, PP38L ( PA-12, 65W )
Sir i have micromax q50 ezpad, i am facing problem to open massege menu, shows alway loadind, and internet menu shows always internet service not ready, kindy help me
actully sir i have micromax Q5 and i m facing the problems like the massage menu is not opening , defult web browser is also not opening ...
Aug 07, 2011 | Cell Phones
Hp laserjet 1214nf mfp show massege fax storage full please tel me how can i solve
You have added to many phone numbers in your fax memory (address book)
pifonski
Feb 19, 2011 | Office Equipment & Supplies
Web roller
This can be solved in resetting the nvm codes
777-077 and 777-078 to 0.
Sep 23, 2008 | Xerox DocuColor 12 Printer
Bettery
to improve the battery life always charge it with switch of the mobile>and do not charge if u got 1 or 2 poing loss>and dont play games >and maximum do not use the vibration>and always use low bright ness>and and always chanrge only one hour if still the same make sure teh battery is original
Nov 13, 2007 | Nokia 6600
Bettery low showing
friend if the p.f ic is shorting than the problem occured 1st replace p.f ic the problem will solve good luck
Aug 15, 2007 | Nokia 1100
Acer Aspire 5735 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
