Question about LG Computers & Internet
LG Monitor won't turn on
It was on this morning, but when I came back after lunch it's now black and won't turn back on no matter what I do.
  • Jennifer Brookman Feb 13, 2012
    From the quick responses I've received, I'm guessing that it's not an easy as I've tested the power and the cables to no avail... it simply won't turn on any more. The monitor is over 4 years old now, so likely just needs to be replaced.
    Thanks for al your help everyone.
    Scholar:
  • 51 Answers
I had this same problem with mine, and had to replace it. Sometimes it's the power supply, but depending on how old it is and how much it's been used, usually unlikely.
If you have a way to check the power supply output for proper current and voltage, and it appears to be fine then that's eliminated as a possibility.
Typically, time to replace it, unfortunately.
I hope this helps!
Posted on Feb 13, 2012
4 Suggested Answers
  • 1684 Answers
SOURCE: My LG L196wtq-BF went black this morning. No
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 31, 2009
  • 644 Answers
SOURCE: Viewsonic VX2255wm - worked this morning - dead this afternoon?
The problem you have sounds like the inverter board has failed it can be repaired by replacing the inverter board which may be a cheaper option than buying a whole new monitor, you can do a search online for lcd repairs and spares to find the part you looking just state your make and model and price one up.
But before you do do that, and you feel confident that you could take the back cover off the monitor, you could have a look for blown capacitors, they are quite a comman fault in lcd monitors, once the back cover is off check the power supply board, it will be where the power cord plugs into the monitor, The capaciters are barrel like in shape with silver tops, check for any leakage from them or on the board surrounding the capacitors, also make sure they are fully flat at the top, if they are slightly domed or pretruded they will need to changed. post back your findings if you do find any bad caps ill will try to explain how to get the right ones and what do to. cheers.
Posted on Feb 01, 2010
ynogami21
  • 670 Answers
SOURCE: My LG 1715S monitor that
Normally the option to reset the monitors default settings is available on the On Screen Display.
Try to Go to Menu look for Advanced Menu or any of that sort and the choice to reset it to factory default should be there.
Otherwise a hardware problem with the color mixer is the cause and that would have to be sent to the service center for repairs.
Other things you can try is to swap cables and try it on a different computer or a TV box.
If the same result happens then definitely it's the color mixer that has gone bad. Maybe it tripped or the part already given up.
You can try contacting LG through 1 (800) 243-0000
Hope this helps!
Posted on Jul 17, 2011
LG monitor will not turn on.
My guess would be a bad power board. The capacitors will blow on them and cause this issue. If you can solder you can take it apart and replace the caps or buy a new Power supply board for your monitor and replace it. The caps hold power for the monitor and when they go bad they may try to hold a little power until they are incapable of doing it anymore. Best way to find out it to unplug monitor from power and computer and take the back off. A blown capacitor will look like a small round thing sticking up and it will look like its oozing something out of it or the top of it will be rounded and bubbled.
Apr 04, 2013 | LG Electronics M2262D 22" LCD Monitor
I drove my car to work this morning and then to my house about a mile for lunch after lunch my car wouldn't start and i hear one tick noise near the power distributor... my battery is fine and eve
Starter solenoid or just a starter bad, sometimes this comes out of nowhere but usually you can hear it start cranking slow shortly before failure.
Oct 10, 2012 | 1999 Mercury Mountaineer
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
I have a dual display at work. one of my two displays is the LG Flatron L1750S. When I go to lunch my LG seems to go into some kind of power saving mode and the screen turns off, but the green light at...
Monitor this gae will more likely to have bad DC filter caps: http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 30, 2010 | LG Flatron L1750S 17" LCD Monitor
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Computers & Internet Logo
91 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
