Question about Miele CVA615 Espresso Machine
Miele coffe machine. Ground coffee is being dumped inside unit. Have taken out brew unit & cleaned but problem persists
  • 10 Answers
SOURCE: Brew unit in Miele coffee system CVA615 block
It sounds like the connector or wiring that links the LCD display board on the door to the main PCB inside the coffe maker has become loose or damaged.
This would cause the text displayed to become scrambled.
Its a 26 way connector that is labelled JP16 (on the next model up) and is next to a large IC.
Posted on Jan 02, 2008
  • 12 Answers
SOURCE: miele coffe machine
The operating instructions are available her: https://centralvacuumstores.com/pdfs/info/viewpdf.php?pdf=CVA2650+Operating+and+Installation+Guide
Posted on Dec 24, 2008
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
SOURCE: how do i clean my miele coffee system cva 4070?
I have a cva4075 so this may not be exactly the same, but on the 4075 you open the front of the machine and pull out the left hand plastic container on the top. Underneath on the right hand side you will see a small flap. On the bottom side of the flap is a red triangle sign. That flap is the top of the funnel for the ground coffee. You drop the cleaning tablet into this funnel.
Posted on Apr 26, 2009
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
Miele Coffee maker CVA 615 makes clicking noise when first turned on. Grinds the coffee but the coffee will not come out. Makes the clicking noise again. It dispenses the used ground coffee correctly to...
If the Hot water and the steam function work fine - then I would say the water system and heaters are good. Are the grounds being dumped in the waste dry? I would guess so. The brew unit drive sounds to be the issue - it has a valve on it that dumps the water to waste if the pressure is to great - the waste valve sometimes gets stuck, but in your scenario it sounds as if the brew unit is not being driven to full compression (the clicking sound) and if that is the case the operation is cancelled. One thing you may try - set the grind to coarse and try a small cup - this is easier on the drive and may work - showing the Valve is good and the brew unit drive is starting to weaken.
Hope that helps
Jan 01, 2018 | Miele CVA615 Espresso Machine
Grinder grinds coffee, but does not make coffe and dumps dry grounfds
Hi your brew unit is blocked. Open the service door and remove the brew unit and wash and rinse under water. Hot is better. The spout on the back side of the brew unit canbe unscrewed and cleaned. This is where most blockages are, Dazza REPAIRER
Sep 25, 2011 | Saeco INCANTO DELUXE Espresso Machine
My miele cva 4075 is not heating the frothed milk or coffee up as well any more...sometimes a Fault 73 shows on the screen..i have cleaned the brew unit with tablets and water etc...what should i do next?
Hello Loriktarrant,
I understand the your Meile CVA4075 is showing you an F73 code. This code means that the brew unit needs to be cleaned. Here is a link to the owners manual on page 40 it shows you how to manually remove and clean the brew unit. The other issue you are having with the milk and coffe not being hot enough could be to the machine needing descaled.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man enter the numbers in the box and click download.
Thank you for choosing FixYa.com
Justin
Mar 12, 2011 | Miele Coffee System
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Coffee is coming out all around the coffe dispenser and very little through the dispenser.
brew unit filters are blocked. take out brew unit, remove screws and clean and replace stainless steel filters.
Jan 27, 2010 | Miele CVA615 Espresso Machine
I have water leaking from under and I cannot see where it is from. I have taken the brew group out and cleaned but it still appears.
try this:move brew unit and you will see white brew valve,clean inside sometimes coffe stuck inside and dont draining water from valve in tray
Aug 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
My meile does not make good coffe
Remove the Brew Unit from the maschine and clean it very well und running water. Thn go into the Main menu and switch back all settings to factory defaults. Then take a vaccum cleaner and put the pipe in the small hole where the coffe falls into the brew unit (knock a bit on the maschin inside). Put out the bean container and do the same with the hole where the beans go into the grinder. Then put everything back in and start a cleaning process for the brew unit (do it 2 times).
After that your Problems must be gone. The Problem is between the grinder and the brew unit. the grinded coffee has bee stuck and is not falling into the brew unit .... that happens when you use beans with lots of oil inside  .... or coated beans .... they "glue" the chute .....
Mr. cool
Jan 01, 2009 | Miele CVA4070 Coffee Maker
Nov 18, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
65 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
