Question about Samsung HT-Z210 Theater System
Auto sound I have two issues 1. How do i turn off the auto sound level correction function on my Samsung HT-Z210? 2. I have a Samsung TV LE40B750 plugged into my HT., when i turn on both with the hdmi cable connecting them, most of the time i cant get any sound out of the HT, i also have an optical cable connected so when i unplug the hdmi i am then able to get the sound to work, although with the blasted auto sound correct, the volume keeps on jumping up and down argggg. thanks for your assistance, much appreciated. Steve
  • 20 Answers
SOURCE: Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Posted on Sep 23, 2008
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
bogue-engine
  • 24 Answers
SOURCE: ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Posted on Jul 22, 2009
SOURCE: My DVD Player (Samsung HT-Z210) displays ?no file?
I have the same problem :S
Posted on Oct 10, 2009
johex
  • 75 Answers
SOURCE: Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Posted on Mar 14, 2010
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Samsung HT-THX25 sound problem
I had the same problem. How i fixed ? I unplugged HT and I kept pressed the power button from DVD for a few seconds. Repeat it, put it in socket and turn it on. It happens from condensation or voltage variations.
Sep 19, 2012 | Audio Players & Recorders
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have a Samsung HT-C550, is there a separate power switch or something for the Sub-woofer? It seems to not have a lot of power.
If it is making any sound at all then it is "on".
Check your subwoofer function and level with Test Tones (page 29) and Auto Sound Calibration (page 30) and don't expect too much from an 8-lb 6.5" subwoofer and a multichannel amp that only draws 75 watts of electricity. Maybe place the sub nearer to a corner.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=Samsung+HT-C550
Mar 23, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Can not get my Samsung TV to recognize the ht system. I am able to get the sound out of the ht system and the video on the tv when i play dvds but the sound will not transfer from the tv to the ht system...
The way mine is hooked up is like this: Ps3, DirecTV box all plugged to my samsung TV and then only thing I have plugged into the Ht box is the hdmi out to TV and an Optical Cable from Tv to HT box. All audio is going to Tv then to HT box and plays all through hometheater box when it is on. Try the optical cable
Sep 22, 2010 | Samsung HTC650 Theater System
Samsung LED UE46B7020 tv wont play sound through my HT-C5500
i know this is going to sound stupid but i couldn't get mine to work either after following every instruction to the T. I then rechecked my optical digital connections again and found that I neglected to remove one on the rubber protective endings. I took it off and plugged the end back into my TV and BINGO! THEATER SOUND from my tv!
The Ticket
May 09, 2010 | Samsung HTC550 Theater System
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Feb 11, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Samsung HT-DS610 says OPEN LOCK
I had this problem yesterday. After not finding a solution anywhere on the internet and nothing in the owner's manual. I remembered years ago that an inoperative TV came back to life by unplugging and then plugging back in....a TV repair tech suggested this and commented that this is functionally like a computer "restart".
Sure enough..................unplugging and then plugging back in fixed mine.
Brian in Austin
Mar 11, 2008 | Samsung HT-DS610 System
Samsung HT-Z210 Theater System Logo
50 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
