Question about Cerwin Vega E-712 Main / Stereo Speaker
Cerwin vega e-712 shutting off
My cerwin vega e-712's shut down while i was playing them loud they both shut down at the same time and wont come back on...i checked both fuses and they are fine i just got them yesterday please help
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
SOURCE: Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Posted on Jan 31, 2010
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
SOURCE: V-35 Cerwin Vega
Turbo 37: Did you ever root cause your V35's? I just ran across this post. I own a pair and have done some amateur / professional speaker building. Let me know if you still want to repair. tro
Posted on Apr 02, 2011
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
My speakers are only playing through the tweeter
If it is happening with both speakers, I would look at the amplifier, or you could have two blown woofers. If it's only one, it may be a wire inside of the box is disconnected or a bad speaker.
Feb 25, 2011 | Cerwin Vega E-712 Main / Stereo Speaker
Can you bridge the vega 124 or just use 1 channel on a punch 400x4
Here are the important concerns:
The power rating of the speaker(400W) should be 25% HIGHER than the maximum output of the amplifier BRIDGED. (Amp bridged output 200W - OK!)
The amplifier will get twice as warm running the speaker when loud.
The impedance of the speaker can be no less than 4 ohms when the amplifier is bridged. (Yes, this speaker is 4 ohms - OK!)
Your punch amp is capable of running TWO Cerwin Vega 124s, bridged.
Apr 02, 2010 | Cerwin Vega 124 Car Subwoofer
When playing on high volume the treble dissapear. I have a 2.6kw Cerwin amp. And Clsc 215 speakers. No bi- wire on my speakers. When I lower the volume the treble returnes. What is wrong???
Sounds like your overpowering the horns and the circuit breaker is tripping to prevent them from blowing. You are running more power then they can handle. You can turn down the volume or will have to purchase higher wattage horns...
Mar 24, 2010 | Cerwin Vega Cerwin-Vega CLSC-215 3-Way...
I am buying a pioneer vsx-d414 receiver and want to no if it will drive my cerwin vega e-712 speakersv says for receivers rated 8ohms or lower.. , just currious
Yes the Pioneer will drive the Cerwin Vega speakers. The Pioneer requires at least 8 ohm speakers and if the Cerwin Vega speakers are 8 ohms, it won't be ******* the receiver.
The speakers you have are high wattage, so the Pioneer may not be able to get the most out of them, but it should be pretty good.
It is always good to have speakers rated at a higher wattage than the receiver, that way the receiver will not fry the speakers. No matter what the wattage of a speaker, it will not pull more power out of an amplifier than the amplifier is capable of delivering. Some people have a mis-conception that if a speaker is higher rated that it will blow up the amp, this is just not true. Speakers do not pull power from an amp, they only put out as much power as the amp is pushing into them. But you can blow up an amp by driving it too hard for too long of time. They just get too hot and the heat stresses the amp circuit after a while.
I hope this helps.
Dave
Jul 18, 2008 | Audio Players & Recorders
Cerwin vega ve-28s
I have the same problem and was told that it is failed amplifier....
Dec 02, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin-Vega EXL1000D Amplifier Broken?
Call Cerwin-Vega and they should offer a "Flat-Rate" repair for it. No matter what is wrong with it, for a flat rate, they will fix it. If not, most any repair shop should be able to. If not, heck, I'LL buy it off ya! (I love Cerwin Vega stuff...)
Sep 14, 2007 | Cerwin Vega EXL-1000D Car Audio Amplifier
Cerwin Vega E-712 Main / Stereo Speaker Logo
74 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
