Question about Yamaha RX-V1800
Yamaha RX-V1800 Zone 2 and Zone 3 connections - no sound output
Attempted to connect outdoor speakers to the Zone 2/Zone 3 speaker connections utilizing the internal amplifiers (SP1 and SP2), but I'm not getting any sound output. I then attempted to connect my Yamaha RX-V995 as a second amplifier using the RX-V1800 RCA connections for Zone 2 and Zone 3 outputs; still no sound output. Have had this amplifier/receiver for several years now with no problems, and I thought adding a zone would be an easy task. Getting very frustrated! Please help!!!
5 Suggested Answers
SOURCE: no zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Posted on Jul 12, 2008
SOURCE: yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Posted on Apr 03, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a the RX-V1700
Strange, if you hook the output from zone 1 to the speakers though it works, correct? You can always just have both sets of speakers connected to zone 1. It sounds like the zone 2 output may have some issues going on here. There shouldn't be anything prohibiting the other sources from playing over zone 2. Check the setup of the receiver and verify there is nothing that "disables" zone 2 for those sources, but to my knowledge (and looking at the manual here) there isn't anything like that.
Tim
Posted on Oct 10, 2010
max6688
  • 54 Answers
SOURCE: RX-V1800. Zone 2 speakers
go to system setting, find Zone2 option, reset output to inner SPK
Posted on Mar 19, 2011
RX-V1800. Zone 2 speakers stopped working and I have no sound coming from them. Suggestions?
Mar 19, 2011 | Yamaha RX-V1800
Have no sound when I connect the rear speakers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
Jul 03, 2009 | Yamaha RX-V1800
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Feb 22, 2009 | Yamaha RX-V1800
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Hookig up rxv1800
This should put you on the right track...
https://www.hifiengine.com/hfe_downloads/index.php?yamaha/yamaha_rx-v1600.pdf
You'll have to register but it is free to do so.
Login HiFi Engine
Aug 14, 2017 | Yamaha RX-V1800
YAMAHA RX-V1800 no Sound
There is an HDMI setting that should be set to through instead of rxv1800. See page 88 of the manual
Sep 13, 2008 | Yamaha RX-V1800
No zone 2 sound coming from yamaha amp rx-v861
Jun 29, 2008 | Yamaha RX-V995 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
NO sound on Zone 2
Did you use the same terminals or two different ones to make the connections?
May 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V1800 Logo
372 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
