Question about Dell Latitude D600 Notebook
Cannot recover data from dell latitude d610 hard drive
Hard drive crashed DST failed Ran chkdsk /p no problems Ran chkdsk /r and never got past 54% Got 99 errors in first 5% of diagnostic tests Data unrecoverable
  • Dell Master
  • 32,281 Answers
Try removing the hard drive and connecting it to ab USN hard drive adapter, then plug this USB adapter and hard drive into the USB port of a working computer.
If this computer can see this as an external storage device and if you are lucky you can open the various folders and files then you can back up your data.
I think this hard drive has failed completely, there are companies that can recover data from faulty hard drives BUT it will cose you an arm and a leg for their services.
Posted on Feb 14, 2012
5 Suggested Answers
  • 38 Answers
SOURCE: DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Posted on Feb 05, 2009
Vaio Tech
  • 166 Answers
SOURCE: Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
try to change out the hard drive on the notebook whid a similar one the size of the hard drive can not be over 160 gb and reinstall windows if it work you may be loss your hard drive
Posted on Oct 10, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My Dell Latitude D830 will not boot up?
Your boot up needs to be repaired...follow the following repair and you should get booted back up. I do believe however that you are losing your hard drive, so watch it carefully and think about getting a backup for your files.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 12, 2009
MSG-CPC
  • 1325 Answers
SOURCE: My son owns a Dell
it may be a hard drive error reporting feature available on SOME (not all) hard drives, via hard drive firmware.
Check your BIOS Setup and see if it is enabled : the HD may have a feature you will be able to correct this by enabling it.
have you tried (bottom right corner of screen) Dell icon support " get in contact with www.dell.com and give them the service tag #.
Posted on Oct 17, 2010
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
you might have jarred the memory loose. take it to a local technician to have them check it out.
Oct 10, 2009 | Dell Latitude D610 Notebook
I am getting a dst short test failed error code 1000=0146
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Sep 10, 2009 | Dell Latitude D610 Notebook
Computer froze
You will need a new hard drive. Its a DST fail "Drive Self Test". If you have the original Windows CD you could boot to the recovery console and backup what you need before swapping out hard drives.
Jun 23, 2009 | Dell Latitude D610 Notebook
D610 DST Short Status Test Fail
Feb 17, 2009 | Dell Latitude D610 Notebook
DST result fails
Feb 05, 2009 | Dell Latitude D610 Notebook PC
Hard Disk Crash
Actually if the hd is corrupted, you can try to go to safe mode or do a chkdsk and then fix boot otherwise you need to contact drivesavers for that.
Nov 02, 2008 | Dell Latitude D600 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
94 people viewed this question
Alun Cox
