Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Bdw13 drains then doesn't fill or wash
Hi, my BDW13 drains but then doesn't progress with the wash cycle
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
SOURCE: BDW13 Element has broken. How do I replace as it's built in
Hi This is a design fault on the Beaumatic dishwasher - it has corroded four times on mine (a built in one) and we have had to have it replaced each time. They only seem to last about 2 years before they go. Although I had two corrode in one year! There isn't a lot you can do with it but I am thinking about replacing it this time for a dishwasher with a concealed element. The Beaumatic Engineer told me it was a common fault with them and to try and keep it wiped dry when not in use!
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
Posted on Oct 15, 2009
  • 7 Answers
SOURCE: getting error code e3 on display- not reaching
the problem is the heat element, it is to replaes..dont now the prise..i am from denmark...
Posted on Oct 29, 2009
Testimonial: "thanks mate its good to know the problem"
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
Posted on Nov 26, 2009
Baumatic BDW13 problems error 4
UNPLUG FIRST. Detach the hose or hoses. Take them put them in a bucket of bleach,and let it go through. Rinse and put back on. It should stop your problems,but it won't smell real nice.... Sorry! Get a fan and open the door if you don't live in a hot city!
Jun 12, 2014 | Dishwashers
Dishes remain dirty
Use a cap of white vinigar in the bottom of the washer before you use it.
May 02, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
I have a baumatic bdw13 dishwashers that is not washing correctly it is reachong correct temperature but not cleaning dishes correctly i have checked filters & put finish rinse aids through & still...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 25, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
Jun 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bumatic dishwasher bdw13 showing error code 1
Ok I think I can really help you here.
This is your error code, sounds like it has problems filling, might also be blocked.
‘E1’ LONGER FILL TIME. FAUCET IS NOT OPENED.
Ensure that inlet hose is not
kinked or crushed
Found the online manual for this model, it is a PDF file so you will need 'Adobe Reader' to read it. (click on link)
http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Manuals/BMBDW13.pdf
That should help you
Bri
Feb 07, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Water not heating
you put the hose to hot water pipe cheers
Jan 18, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
49 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
